Page 1 of 3 1 2 3
727 park grind #2555340
09/27/18 12:55 AM
09/27/18 12:55 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
I have a big block 727 and its a factory console shift set up.the car will shift just fine.when i put in park the button gets kinda stuck intel it releases.the car will make alittle grind sound.is something out of adjustment?
Re: 727 park grind [Re: mopar muscle7271] #2555363
09/27/18 02:02 AM
09/27/18 02:02 AM
I'm thinking you need to slightly lengthen the linkage for more pawl engagement into the trans.
Re: 727 park grind [Re: RapidRobert] #2555509
09/27/18 12:47 PM
09/27/18 12:47 PM
moparx Offline
moparx  Offline
linkage adjustment or check first thing to do. also, check the pivot bushings in the linkage for wear. all the button on the shifter does, is bypasses the gate detents on the shifter.
beer
Re: 727 park grind [Re: mopar muscle7271] #2555551
09/27/18 02:29 PM
09/27/18 02:29 PM
las vegas,nv
las vegas,nv
Oh ok i though i was low on fluid.it seems to be ok.its makin a grind noise alright when i put it in park.
Re: 727 park grind [Re: mopar muscle7271] #2555555
09/27/18 02:38 PM
09/27/18 02:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you at a dead stop when shifting to Park? If the car lurches a little after shifting to Park and the grinding occurs, it's not fully in Park and, as suggested, the linkage is the problem.
Has it always done this or did it just start?
Re: 727 park grind [Re: mopar muscle7271] #2555573
09/27/18 03:06 PM
09/27/18 03:06 PM
las vegas,nv
las vegas,nv
I have the car on jack stands ounce i put the level in park it will grind then the grinding will slowly stop after a minute or so.i had to hurry up and turn it off.so it doesnt ruin something.it just started
Re: 727 park grind [Re: mopar muscle7271] #2555577
09/27/18 03:14 PM
09/27/18 03:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The rear wheels have to be at a dead stop before engaging Park, on jackstands use the brakes or stay away from Park. "A minute or so" of grinding isn't good on parts. rolleyes
Re: 727 park grind [Re: mopar muscle7271] #2555585
09/27/18 03:40 PM
09/27/18 03:40 PM
las vegas,nv
las vegas,nv
The wheel do stop when in park.every time i pit in park it will grind.i know it isnt good thats why hurry up and shut it off.
Re: 727 park grind [Re: John_Kunkel] #2555746
09/27/18 11:19 PM
09/27/18 11:19 PM
las vegas,nv
las vegas,nv
Its not fully in park the back tires turn by hand at the moment.they shouldn't unless its out of park.the lever is in park not the linkage.hopin thats all it is the linkage not further damage.that grindin was bad.could the bands be out of adjustment?
Re: 727 park grind [Re: mopar muscle7271] #2555754
09/27/18 11:23 PM
09/27/18 11:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Are you using the brake to stop the rear wheels from moving before shifting into Park?
If so, your rear brakes may not be working.
Re: 727 park grind [Re: mopar muscle7271] #2555756
09/27/18 11:24 PM
09/27/18 11:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bands have nothing to do with park. Park is just a rod that moves a lever that drops into a cogged gear on the output shaft.
Re: 727 park grind [Re: Alaskan_TA] #2555764
09/27/18 11:34 PM
09/27/18 11:34 PM
las vegas,nv
las vegas,nv
Yah i used the push the brake pedal when shiftin into park.
Re: 727 park grind [Re: stumpy] #2555766
09/27/18 11:35 PM
09/27/18 11:35 PM
las vegas,nv
las vegas,nv
Oh ok
Re: 727 park grind [Re: mopar muscle7271] #2555767
09/27/18 11:35 PM
09/27/18 11:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Did you make sure the wheels had stopped spinning after that & before shifting to Park?
Re: 727 park grind [Re: Alaskan_TA] #2555775
09/27/18 11:51 PM
09/27/18 11:51 PM
las vegas,nv
las vegas,nv
Yah wheels stop ounce i put in park with the grind sound.it is one wheel tire fryer.it has 8 1/4 rear in it.
Re: 727 park grind [Re: mopar muscle7271] #2555934
09/28/18 12:18 PM
09/28/18 12:18 PM
moparx Offline
moparx  Offline
the wheels will stop when in park, but you MUST STOP the wheels with the BRAKES BEFORE you attempt to put it in park. just because you have your foot on the brake pedal, and are depressing it, doesn't necessarily mean the rear wheels are stopped. all automatic transmissions will grind going into park with the rear wheels turning, even ones with correctly adjusted linkage. "one wheel peel" doesn't matter.
beer
Re: 727 park grind [Re: moparx] #2555940
09/28/18 12:28 PM
09/28/18 12:28 PM
Yeah I have been bit by that (when up on stands) cuz your brain automatically thinks that you are "stopped" (& OK to go into park) cuz the car ain't moving.
Re: 727 park grind [Re: moparx] #2555961
09/28/18 01:29 PM
09/28/18 01:29 PM
las vegas,nv
las vegas,nv
Oh ok i have the car off and lever in park shouldn't the rear tires not by moving by hand unless its out of park?
Re: 727 park grind [Re: mopar muscle7271] #2555966
09/28/18 01:40 PM
09/28/18 01:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
step away from the vehicle
Get competent, on site help.
You do not know what you are doing.
one wheel peel will let the wheels turn, on jack stands, when in park. They will turn different directions.
Don't be the exception.
Re: 727 park grind [Re: Supercuda] #2556081
09/28/18 08:24 PM
09/28/18 08:24 PM
las vegas,nv
las vegas,nv
I dont need some smart dam remark.i question here.dont tell me to step away from my own car.what a troll
Page 1 of 3 1 2 3
