Silly Q- how are converter bolts so small?! #2554835
09/26/18 12:01 AM
09/26/18 12:01 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
I just put a b&m 2500 stall converter in a 727 behind a 512 stroker. I used a beefy solid flexplate which bolted to the crank with six beefy ARP bolts.
Then the flexplate boltes to the torque converter lugs with four tiny little bolts!
What gives? I suspect leverage comes into play here but how does all that beef trickle down to four tiny bolts? I felt like I had to be extra careful to not shear them while torquing with blue loctite! I’m always blown away when I see ‘weakest link’ items- 1/2” front leaf spring bolts, the single pin that holds the swinging basket to the frame on a ferris wheel...
Obviously it works or they wouldn’t make them like that but does anybody smartener than me have an explanation?
Re: Silly Q- how are converter bolts so small?! [Re: radar] #2554866
09/26/18 01:22 AM
09/26/18 01:22 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's 5/16 sae threads and should be cranked down, loctite helps, and should be checked periodically. The heavier 7/16 bolts need to be fairly tight as well. When I worked at chev, it was not rare at all for those 3 bolts to loosen on everyday drivers. Those were 3/8 or 10 mm. They started using locking compound too.
Re: Silly Q- how are converter bolts so small?! [Re: radar] #2554879
09/26/18 01:47 AM
09/26/18 01:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
It's in a sheer situation, but not like dropping the clutch at 5000 rpm. A race converter uses the big bolts like the crank size. I'm sure there's some graph online to show the specs of bolt sheer.
Re: Silly Q- how are converter bolts so small?! [Re: radar] #2554882
09/26/18 01:56 AM
09/26/18 01:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Imagine the increase in strength when going from 3 bolts to 4. (Chevy/GM to Mopar)
Re: Silly Q- how are converter bolts so small?! [Re: Kern Dog] #2554884
09/26/18 02:01 AM
09/26/18 02:01 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Some of the 427 Chevys used six..... eek
Re: Silly Q- how are converter bolts so small?! [Re: John Brown] #2554922
09/26/18 09:33 AM
09/26/18 09:33 AM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
They increased the size of the converter bolts for the hemis. The reason that they don't need to be as big as the crankshaft bolts, is because there is less force on the converter bolts than the crank bolts. Torque = force X moment arm length. The bolts further from the crank centerline (longer moment arm) have less force on them. It's lever theory, like you mentioned.
Re: Silly Q- how are converter bolts so small?! [Re: BLACKHEMIRR] #2555021
09/26/18 01:41 PM
09/26/18 01:41 PM
dogdays Offline
dogdays  Offline
There is another factor involved as well and that is friction.
Friction between the flexplate and the converter lugs is what transfers the torque. The bolts are loaded in tension and should not see shear as we normally think of it.
R.
Re: Silly Q- how are converter bolts so small?! [Re: dogdays] #2555097
09/26/18 04:46 PM
09/26/18 04:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree in theory but, being the fastidious type, I always try to leave all the bolts loose and turn the converter so that it is loaded against the side of the holes before final tightening.
Re: Silly Q- how are converter bolts so small?! [Re: John_Kunkel] #2555112
09/26/18 05:26 PM
09/26/18 05:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had three of the four loosen up on my 69 D200 a couple years ago. The guy who put the converter in 18 years ago apparently didn't torque them down. mad The was the truck was running and sounding I thought I had spun a bearing so I took the engine out leaving the trans in the truck. Needless to say I was pissed when I saw the torque converter flop after taking it out of the trans... eyes
JB Rhinehart, Realist
A-Body's RULE!
Re: Silly Q- how are converter bolts so small?! [Re: dogdays] #2555129
09/26/18 06:21 PM
09/26/18 06:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
R.
But the longer moment arm is still very much in play as to where the "friction" is applied, to be clear.
Re: Silly Q- how are converter bolts so small?! [Re: radar] #2555140
09/26/18 06:34 PM
09/26/18 06:34 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you torque them to the proper specs you should be golden up twocents
The only ones I've seen or heard of loosening up was due to inattention to the tightening specs. or a out of balanced torque converter or motor work shruggy
My current bracket car with a glide with a 9 inch torque converter that has 3 1/2 inch bolts in it due to the former owner running a blown B1 motor in it, most of the good race Hi Po torque converters for Glide use three 7/16 bolts with lock nuts on the other end, no threads in the converter lugs shruggy
Re: Silly Q- how are converter bolts so small?! [Re: radar] #2555162
09/26/18 07:29 PM
09/26/18 07:29 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yeah when I first put a B.B. in my dart I thought how stupid are these 5/16 bolts. I later switched converter and the better converter had 7/16.
I still hate that threaded converter lug deal.
I had them back out and I swore it was a rod knock.
