Re: Silly Q- how are converter bolts so small?!
[Re: dogdays]
#2555129
09/26/18 06:21 PM
09/26/18 06:21 PM
Posts: 22,695 Bitopia
jcc
Bitopia
There is another factor involved as well and that is friction.
Friction between the flexplate and the converter lugs is what transfers the torque. The bolts are loaded in tension and should not see shear as we normally think of it.
R. But the longer moment arm is still very much in play as to where the "friction" is applied, to be clear.
[Re: radar]
#2555162
09/26/18 07:29 PM
09/26/18 07:29 PM
Posts: 619 nj
JAMESDART
nj
Yeah when I first put a B.B. in my dart I thought how stupid are these 5/16 bolts. I later switched converter and the better converter had 7/16. I still hate that threaded converter lug deal. I had them back out and I swore it was a rod knock.
