1984 D100 2wd Turn signal lever? #2554505
09/25/18 03:09 PM
09/25/18 03:09 PM
Pennsylvania
scannman70 Offline OP
Pennsylvania
My 2wd 1984 Truck, Non tilt, just a basic Steering Column.
When I use my passenger side turn signal, the turn signal lever won't engage, you have to hold it in place to make it blink, feels like something is stopping it from "clicking" into place.
Drivers side it works just fine.
Before I take this apart anyone have this before, know what I may be getting into?/
Thank you
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2554526
09/25/18 03:46 PM
09/25/18 03:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Replace the turn signal switch. Very simple job. Most big parts stores will loan out a steering wheel puller set. https://www.youtube.com/watch?v=d7cz8LA9NKo
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2554618
09/25/18 06:06 PM
09/25/18 06:06 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
there are plastic fingers that break off that hold the lever in place
1981 Dodge D150 360 auto
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2554769
09/25/18 10:33 PM
09/25/18 10:33 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
You might even get it off without a puller if you're lucky. I was able to just do mine without a puller. Remember to line the front wheels up straight and put the steering wheel back on straight.
Facts are stubborn things.
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2554880
09/26/18 01:48 AM
09/26/18 01:48 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Steering wheel and the shaft are marked so it is easy to put it back on correctly.
Re: 1984 D100 2wd Turn signal lever? [Re: stumpy] #2554988
09/26/18 12:35 PM
09/26/18 12:35 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I didn't see any markings on my '79, and the wheel was off when I bought the truck. Maybe just gone with time? Sure makes sense they would be marked!
Re: 1984 D100 2wd Turn signal lever? [Re: stumpy] #2555001
09/26/18 01:04 PM
09/26/18 01:04 PM
Pennsylvania
Pennsylvania
Any Idea where to get a new turn signal switch? Before I call the dummies we have at part stores around here??
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2555032
09/26/18 02:05 PM
09/26/18 02:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The local parts store dummies. Go online and look up the parts numbers on the parts stores site. Then it will be easier to get what you need.
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2555132
09/26/18 06:24 PM
09/26/18 06:24 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2556417
09/29/18 10:09 PM
09/29/18 10:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I found a NOS one on ebay for $40 for my '79 Power Wagon. NOS Mopar will be so much better than any aftermarket and you might find one cheap enough. If you can just get the part number.
This could be what you need
https://www.ebay.com/itm/82-83-DODGE-RAM...9/222499837772?
Re: 1984 D100 2wd Turn signal lever? [Re: scannman70] #2557085
10/01/18 03:52 PM
10/01/18 03:52 PM
Pennsylvania
Pennsylvania
Got one guys, thanks,
