Horn/Horn relay question #2554642
09/25/18 06:32 PM
09/25/18 06:32 PM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
I installed a new dash wire harness and new engine wire harness but my horn isn't working. The horn and relay are original. The car is a 70 Roadrunner. The horn worked when tested when I first got the car running a few months ago. The horn does nothing now. The horn relay clicks when the horn button is pushed but still nothing from the horn. I ran a wire from the battery directly to horn and still nothing. Is the horn no good, the relay no good or both?
Re: Horn/Horn relay question [Re: Kevlisa] #2554647
09/25/18 06:36 PM
09/25/18 06:36 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Make sure the horn has good ground.
If it still not honking,replace it.
Relay is getting power when you here it click.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Horn/Horn relay question [Re: 68Cbarge] #2554659
09/25/18 06:53 PM
09/25/18 06:53 PM
Buford, GA
I_bleed_MOPAR Online content
I_bleed_MOPAR  Online Content
Buford, GA
iagree
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Horn/Horn relay question [Re: Kevlisa] #2554662
09/25/18 06:57 PM
09/25/18 06:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just because the relay clicks does not mean it is sending anything to the horn. Put a meter, or at least a test light, on it and see if there is anything coming out of the relay. If so, see if there is anything at the horn.
Or throw money at it.
Don't be the exception.
Re: Horn/Horn relay question [Re: Supercuda] #2554668
09/25/18 07:05 PM
09/25/18 07:05 PM
Buford, GA
Buford, GA
wink
Tim
'71 Charger 383/727
Re: Horn/Horn relay question [Re: Kevlisa] #2554678
09/25/18 07:20 PM
09/25/18 07:20 PM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
Test light on the wire at the horn lit up when horn button was pressed. I guess I got confused by the fact that the horn worked when tested initially. Looks like the horn is bad now. Also explains why it won't honk when directly hooked to the battery. New horn ordered, hopefully problem solved. Thanks for the replies and advise.
Re: Horn/Horn relay question [Re: Kevlisa] #2554684
09/25/18 07:33 PM
09/25/18 07:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I need new glasses
Re: Horn/Horn relay question [Re: Kevlisa] #2554695
09/25/18 07:52 PM
09/25/18 07:52 PM
there is a small "trimmer" screw on the horn body, turn it a C hair CW & CW then back to your starting point & jump fire to the horn again & see if it sounds (I'm assuming it is grounded). Do ya feel lucky?
