Re: Horn/Horn relay question
[Re: Kevlisa]
#2554647
09/25/18 06:36 PM
09/25/18 06:36 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Make sure the horn has good ground. If it still not honking,replace it. Relay is getting power when you here it click.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: Kevlisa]
#2554662
09/25/18 06:57 PM
09/25/18 06:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just because the relay clicks does not mean it is sending anything to the horn. Put a meter, or at least a test light, on it and see if there is anything coming out of the relay. If so, see if there is anything at the horn.
Or throw money at it.
[Re: Supercuda]
#2554668
09/25/18 07:05 PM
09/25/18 07:05 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
I ran a wire from the battery directly to horn and still nothing. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Kevlisa]
#2554695
09/25/18 07:52 PM
09/25/18 07:52 PM
RapidRobert
Looks like the horn is bad now. there is a small "trimmer" screw on the horn body, turn it a C hair CW & CW then back to your starting point & jump fire to the horn again & see if it sounds (I'm assuming it is grounded). Do ya feel lucky?
