Engine induced muffler drone? Driving me nutts #2554187
09/24/18 07:19 PM
09/24/18 07:19 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have a drone from the exhaust system on my ram van 2001- 5.9. It only does it in third (the most) and (much less) in overdrive at 900-2100 rpm at part throttle, coasting is totally quiet other than road noise. What ideas can you give to change-adapt to my single exhaust system? By the way,new muffler and cat, stock system.
Re: Engine induced muffler drone? Driving me nutts [Re: cudaman1969] #2554269
09/24/18 10:42 PM
09/24/18 10:42 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Install a resonator in a section of straight pipe - as long as you can fit. Good glasspack will do. You want something with small louvers, not smooth perforations.
Re: Engine induced muffler drone? Driving me nutts [Re: cudaman1969] #2554296
09/25/18 12:09 AM
09/25/18 12:09 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I noticed on my wagons that they're much more likely to have drone than my sedans/hardtops, using essentially the same exhaust system; you're basically sitting in a drum. Anything you can do to break up that big chamber - insulation, maybe even a divider being it's a van - will help. Tailpipes and larger/quieter mufflers help, as should the resonator already mentioned.
Re: Engine induced muffler drone? Driving me nutts [Re: topside] #2554301
09/25/18 12:18 AM
09/25/18 12:18 AM
X3 on an added "resonator" just a long glasspack(s) in the rear tailpipes will take care of it.
Re: Engine induced muffler drone? Driving me nutts [Re: cudaman1969] #2554348
09/25/18 03:12 AM
09/25/18 03:12 AM
fredericksburg,va
fredericksburg,va
Resonator was what I was thinkng too, I'll have to check length for fit, not much pipe back there. Will another short muffler work, or would that be to much back pressure?
Re: Engine induced muffler drone? Driving me nutts [Re: cudaman1969] #2554414
09/25/18 11:47 AM
09/25/18 11:47 AM
No you'd be fine on that
Re: Engine induced muffler drone? Driving me nutts [Re: cudaman1969] #2554445
09/25/18 12:28 PM
09/25/18 12:28 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On both my 360 cars (74 Duster360 and 70 Sport Satellite with 360 in it), there is a "drone" at 2000 rpm . . . I can tell the rpm just by that sound ! Lower or higher RPM, no issue . . . . both are dual exhaust with full tailpipes and "h" pipe . . . from same exhaust shop !
