Engine induced muffler drone? Driving me nutts
#2554187
09/24/18 07:19 PM
09/24/18 07:19 PM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
I have a drone from the exhaust system on my ram van 2001- 5.9. It only does it in third (the most) and (much less) in overdrive at 900-2100 rpm at part throttle, coasting is totally quiet other than road noise. What ideas can you give to change-adapt to my single exhaust system? By the way,new muffler and cat, stock system. Thanks
Re: Engine induced muffler drone? Driving me nutts
[Re: cudaman1969]
#2554269
09/24/18 10:42 PM
09/24/18 10:42 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
Install a resonator in a section of straight pipe - as long as you can fit. Good glasspack will do. You want something with small louvers, not smooth perforations.
[Re: topside]
#2554301
09/25/18 12:18 AM
09/25/18 12:18 AM
RapidRobert
X3 on an added "resonator" just a long glasspack(s) in the rear tailpipes will take care of it.
