Wiring Harnes .. 70-B-body...Need advice! what brand..! #2554254
09/24/18 10:10 PM
09/24/18 10:10 PM
Ontario. Canada
SunnyMopar Offline OP
Ontario. Canada
HI.. I am in the process of deciding to replace wiring harness for a 70- b-Body.. has anyone replaced one recently!.. What is the best Harness on the market... and is it complete with fuse box.. ect...!
I saw on Classic industry mopar suppliers they sell:
Painless & Ron Francis
please help.. Thank you so much!
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554264
09/24/18 10:36 PM
09/24/18 10:36 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
M&H is another option: http://www.wiringharness.com/
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554266
09/24/18 10:40 PM
09/24/18 10:40 PM
Fort Walton Beach
mothermopar Offline
mothermopar  Offline
Fort Walton Beach
+1 for M&H never had an issue with their stuff and it's just like the factory, regarding colors.
1969 Superbee, Hemi, 4 Spd, Supertrack Pack
2007 Dodge Ram 2500, 4x4, 5.9 Cummins
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: mothermopar] #2554297
09/25/18 12:09 AM
09/25/18 12:09 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
M&H is my only consideration in a build, but regardless of the mfg you choose, take the time to compare it to the original, as well as the factory service manual diagrams, and take the time to check continuity of EACH circuit with a quality meter BEFORE you install it
Mike
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554338
09/25/18 02:02 AM
09/25/18 02:02 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
M&H
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554359
09/25/18 06:23 AM
09/25/18 06:23 AM
Missouri
70X Offline
70X  Offline
Missouri
Just put one from classic industries in my 70 Charger. I'm happy with it for the most part, everything works, only complaints are the door jamb switch wires do not fit through the holes in the pillars and the turn signal switch and ignition switch plugs are very tight and hard to get plugged into the new under-dash harness. Not sure what brand they sell but would buy another one IMO.
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554373
09/25/18 09:46 AM
09/25/18 09:46 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Put an M&H in my GTX dash. Everything was good with the exception of the 5 wire gang plug for the printed circuit board. I ended up cutting their ends off and finding correct bullet connectors at my local electric supply house and used an original plastic connector holder. So far so good.
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554446
09/25/18 12:32 PM
09/25/18 12:32 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
M&H....From Year One.... with a 30% off deal...
Be prepared to wait a bit....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Wiring Harnes .. 70-B-body...Need advice! what brand..! [Re: SunnyMopar] #2554449
09/25/18 12:44 PM
09/25/18 12:44 PM
South Carolina
carhunter Offline
carhunter  Offline
South Carolina
I put one in my 70 RR about 5 yrs. ago.Year one with the 30% off.M&H makes the best one IMHO does comes with fuse box.I also did engine bay and back lights.No cutting at all color coded,easy to do.
