Survey Please #2554188
09/24/18 07:19 PM
09/24/18 07:19 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
Ok so I went to a car show on Saturday and I,m getting really tired of 3,000 rpm when i,m going 60. So here is what I have! 71 RR with a 440+6 auto trans and 4:11 rear gears with P275-60-15 rear tires. Going to change the rear gears so do i go with 3:55 or 3:23 . I,m afraid that 3:23 won,t give the low gear kick that I like. Opinions Please!!!!!!!
Re: Survey Please [Re: 72 RR DUDE] #2554189
09/24/18 07:25 PM
09/24/18 07:25 PM
New York
rarefish Offline
rarefish  Offline
New York
Re: Survey Please [Re: 72 RR DUDE] #2554192
09/24/18 07:31 PM
09/24/18 07:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For the street with 15" tires, I love the 3.55s
That is what my T/A had, thousands of happy miles. :-)
Re: Survey Please [Re: 72 RR DUDE] #2554252
09/24/18 10:07 PM
09/24/18 10:07 PM
State, country, etc.
gss Offline
gss  Offline
I would go with the 3.23 if you do any significant highway driveway.
Re: Survey Please [Re: gss] #2554259
09/24/18 10:20 PM
09/24/18 10:20 PM
Hamburg, Pa.
Hamburg, Pa.
Not going to do alot of highway but want it to be a good all around driver.
Re: Survey Please [Re: rarefish] #2554289
09/24/18 11:45 PM
09/24/18 11:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By rarefish
Not everyone wants to spend $2500/$3000 for a gear change.
Re: Survey Please [Re: 72 RR DUDE] #2554292
09/25/18 12:04 AM
09/25/18 12:04 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Personally I'd keep the 4.11(?)gears, and go with a 4spd auto OD or 5/6 speed manual...but that's just me, IMHO the 3:23/3:55 will disappoint you from a performance stand point on the street or track
Re: Survey Please [Re: 62maxwgn] #2554294
09/25/18 12:08 AM
09/25/18 12:08 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
3:55 with a 26 inch tall tire is what I have ran in past cars and what I put together for my Dart. It's usable on the freeway for reasonable distances. I would not want to do an 8 hour drive with that setup, but a short jaunt on the freeway to the next town for a car show is doable.
Your 275/60-15 tires are taller than what I have used so the 3:55 may be better than the 3:23.
Re: Survey Please [Re: 72 RR DUDE] #2554300
09/25/18 12:16 AM
09/25/18 12:16 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cheapest: tall rear tires
Most adaptable to wide range or driving: more gears, overdrive
Least amount of adaptation: Gear Vendors OD unit.
Every option I've seen for OD - auto or stick - ends up at least $3000 by the time you're done, plus some require cutting the floor or t-bar crossmember.
Personally, I'm not a fan of doing that.
The more I look at the available options, the better I like the GV. Plus the one in my Dually since 1994 has been bulletproof.
Re: Survey Please [Re: 72 RR DUDE] #2554325
09/25/18 01:20 AM
09/25/18 01:20 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
3.23 for sure grip!! lol
Re: Survey Please [Re: ngpSatellite] #2554457
09/25/18 01:14 PM
09/25/18 01:14 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
My Satellite has 3.55's with L 60-15 rear tires, I know my speedo is accurate because I took the time changing the trans gear and checking with a GPS. I go 65-70 on hyway at about 3000-3200 RPM's.
Ron
Re: Survey Please [Re: 72 RR DUDE] #2554463
09/25/18 01:26 PM
09/25/18 01:26 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
3:55
Re: Survey Please [Re: 72 RR DUDE] #2554475
09/25/18 01:51 PM
09/25/18 01:51 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I can’t stand highway rpm’s. I have a 68 charger with a mild 408 stroker with 2.94’s in it that pulls nice and hard to 13.28 in the 1/4. and I only use 1st. and 2nd.
I still think it revs to much on the highway at 70mph.
I also have a 67 Coronet with 3.55’s and a gear vendors and it also revs to much for me on the highway. It pulls real nice through the gears though. Gears vendors unit don’t drop down as much as I would like.
Re: Survey Please [Re: 72 RR DUDE] #2554476
09/25/18 01:54 PM
09/25/18 01:54 PM
Kirkland, Washington
Pacnorthcuda Offline
3.55. I' run 3.55 on my 440 Cuda, 275/60/15s. More highway than city now that I've moved but it's still a great gear.
ANY rear gear is a compromise IF there is no overdrive and the car runs a mix of city and highway...period.
3.55 isn't perfect in town, and it isn't perfect on the freeway....it's just better at both (or doesn't suck as much if you are a glass half empty guy) than the others.
Re: Survey Please [Re: 72 RR DUDE] #2554518
09/25/18 03:25 PM
09/25/18 03:25 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Cheapest and best option is put quiet mufflers on it and unplug the tach. 3000 rpms won't hurt a thing. Put a stand alone shift light in it for when you drive
Re: Survey Please [Re: 72 RR DUDE] #2554522
09/25/18 03:33 PM
09/25/18 03:33 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
If it's a cruiser/driver, go 3.23. A 440 makes plenty of torque to turns the tires still. If your barely on the highway 3.55s would be ok too with the 28" tires.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Survey Please [Re: 72 RR DUDE] #2554712
09/25/18 08:46 PM
09/25/18 08:46 PM
Put the 3.23 in it, the torque converter will allow you to still spin he tires at will shruggy twocents work
Actually the 3.23 will make the tires spin longer in first gear, don't ask me how I know that devil scope
Most butt dyno are very misleading when it comes to all out performance shock The time slip is not up scope
Re: Survey Please [Re: 72 RR DUDE] #2554724
09/25/18 09:09 PM
09/25/18 09:09 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've run 276, 323 AND 488 GEARS in the same car over the years. The 488 stand out as not drivable. Negligible difference between 323 and 276 performance wise but I'm thinking ill go back to 276 when the new torque engine goes in.
I also run an 833od with all the gears.
Angry white pureblood male
Re: Survey Please [Re: Alaskan_TA] #2554728
09/25/18 09:12 PM
09/25/18 09:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
3.55 all the way
Re: Survey Please [Re: 72 RR DUDE] #2554794
09/25/18 11:13 PM
09/25/18 11:13 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I think going from 4.10 gears to 3.23 you will not be happy with the results. I would go with the 3.55 gears.
