Exhuast Manifold Gaskets
#2553703
09/23/18 04:56 PM
09/23/18 04:56 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hello! Somebody had the exhaust manifolds off in the early 80s on my '70 GTX. They used header gaskets when they put it back toget5her. I want to remove to exhaust manifolds because the gaskets are leaking. What kind of headaches am I going to occur?
What would be the first step to getting them off? Do I need to heat the bolts? Or do I just spray them down with WD-40? Also, what type of gaskets should I replace them with? Any ideas or information would be appreciated. Thanks!
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Exhuast Manifold Gaskets
[Re: GTXKARL]
#2553753
09/23/18 06:20 PM
09/23/18 06:20 PM
RapidRobert
I'm a SB guy but I think all BB ex bolt holes are wet so drain the coolant down (2 gallons oughta be plenty). No heat, just a breaker bar & give it a good bump to shock em loose.
[Re: bobby66]
#2553855
09/23/18 10:23 PM
09/23/18 10:23 PM
RapidRobert
^^^ agreed, if these are exposed threads/nuts then spray em/let em soak for a day. you dont want to snap any studs
