Exhuast Manifold Gaskets
#2553703
09/23/18 04:56 PM
09/23/18 04:56 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hello! Somebody had the exhaust manifolds off in the early 80s on my '70 GTX. They used header gaskets when they put it back toget5her. I want to remove to exhaust manifolds because the gaskets are leaking. What kind of headaches am I going to occur?
What would be the first step to getting them off? Do I need to heat the bolts? Or do I just spray them down with WD-40? Also, what type of gaskets should I replace them with? Any ideas or information would be appreciated. Thanks!
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
