Metal fuel line separation 340 Six Pack #2553780
09/23/18 07:29 PM
09/23/18 07:29 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Is there a trick to remove the factory fuel lines from the six pack setup? I can't get them to un-thread so I can remove the carbs.
1970 EK2 T/A 727
Re: Metal fuel line separation 340 Six Pack [Re: f2502011] #2553787
09/23/18 07:46 PM
09/23/18 07:46 PM
Shoreline, Washington
72roadrunnergtx Offline
Pull rear carb first, unscrew the flare nut at the rear y-fitting to the rear carb first, then center carb, flare nut at the forward y-fitting to center carb. Use a flare nut wrench and support the fitting.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Metal fuel line separation 340 Six Pack [Re: 72roadrunnergtx] #2553788
09/23/18 07:49 PM
09/23/18 07:49 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Are you talking about the brass junction block fitting in the middle that's 3 way? I can't get them to budge. Is anything reverse threaded??
1970 EK2 T/A 727
Re: Metal fuel line separation 340 Six Pack [Re: f2502011] #2553791
09/23/18 07:54 PM
09/23/18 07:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not reverse threading. Try some PB blaster on the fittings and let it soak for a while. Be sure to use a line wrench so you don't deform or round off the fittings.
Re: Metal fuel line separation 340 Six Pack [Re: f2502011] #2553798
09/23/18 08:01 PM
09/23/18 08:01 PM
Use a 5/8” open ended wrench to support the block fitting if necessary.
Re: Metal fuel line separation 340 Six Pack [Re: f2502011] #2554751
09/25/18 09:58 PM
09/25/18 09:58 PM
london ontario
SYDWAZ340 Offline
SYDWAZ340  Offline
london ontario
I had the same problem with my 340 six pack that hasn't been apart for 30 yrs. I couldn't get some of fittings apart no what I tried. Ended up cutting the fuel lines to get them apart. Ordered whole tubing kit for all 3 carbs from Mancini Racing for $24.95 plus shipping. Arrived in Ontario 7 days later. Looked like they ordered the parts from Right Stuff Ltd. Problem solved and looks great
Re: Metal fuel line separation 340 Six Pack [Re: SYDWAZ340] #2554759
09/25/18 10:08 PM
09/25/18 10:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I sure don't blame you. For 25 bucks new lines are worth it sometimes especially after 30 years.
Hey welcome to Moparts. I kind of think of your name as sawzall 340, kind of what you just told us about using a saw on your 340! up laugh
