Originally Posted By 72roadrunnergtx
Pull rear carb first, unscrew the flare nut at the rear y-fitting to the rear carb first, then center carb, flare nut at the forward y-fitting to center carb. Use a flare nut wrench and support the fitting.
Are you talking about the brass junction block fitting in the middle that's 3 way? I can't get them to budge. Is anything reverse threaded??
1970 EK2 T/A 727
