Page 3 of 3 1 2 3
Re: Camshaft for street 440 [Re: 70charger512] #2550776
09/16/18 09:29 PM
09/16/18 09:29 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Originally Posted By Nick Stevanovski
My one final question would be, with this setup and the voodoo cam, should i go with 3.55 or 3.73 gears? Again its a daily driver that I’d still like to rip off the line every once in awhile.
I have a 440 Cuda hemi 4 speed, 3.55 car. DEFINATELY DO NOT go with 3.23s! You have overdrive, my first choice would be 3.73's if you have them, but 3.55s will work fine.
I THINK I am running the Lunati Voodoo you are talking about (they changed part numbers several years ago and I lost track).
My cam is the .493 / .513 lift. 268/272 duration(I think).
Powerband comes on at 1900 and pulls hard. Anything less than 1900 will lug under throttle. I have not found the top end, but I've only looked for it up to about 6200.
I would LOVE to have an overdrive, but it's not worth the expense and work to go for it...for me.
Yes thats the exact one (they changed from 5 digit numbers to long ones if im not wrong, if im right about that yours is the 60303). So off the line youd say (in a race situation) to dump the clutch at 1900?
Yes, mine is the 60303. It's a great mid-range power cam.
No, I try to hold the motor at 2500 and apply throttle at the same time as clutch.
Re: Camshaft for street 440 [Re: Pacnorthcuda] #2550801
09/16/18 10:12 PM
09/16/18 10:12 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
Correct me if im wrong, but it sounds like you’re saying its not too good on the low end. How is it as a normal driver, does it take much revving to move from a stoplight?
Re: Camshaft for street 440 [Re: 70charger512] #2550813
09/16/18 10:35 PM
09/16/18 10:35 PM
I can take off from a dead stop as slow or as fast as I want. I can cruise along at say 25-35 mph at 1500 just fine, but I can't mash the pedal unless it's 1900 or above or it will lag. If it was an auto it wouldn't matter. It's a stump puller from 1900 and up.
Any sort of spirited driving and none of this noticeable as the engine is on its powerband.
Degreed it at 107 (that was straight up) then when I was in there for another reason I decided to advance it 2 degrees just for the hell of it. It lowered the powerband by about 100 rpm.
Re: Camshaft for street 440 [Re: Pacnorthcuda] #2550816
09/16/18 10:49 PM
09/16/18 10:49 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
If i were to get 3.55 or 3.73 that would help alot with the low rpm lugging correct? I know for sure im getting one of those two, just dont know which yet. Anyone have opinions on rear end gears?
Re: Camshaft for street 440 [Re: 70charger512] #2550833
09/16/18 11:08 PM
09/16/18 11:08 PM
Of course, higher rear gear numbers will get you into the powerband much faster. Your overdrive gives you the option to select rear gears that you otherwise wouldn't be happy with.
You may even find yourself skipping shifts--I skip 2nd fairly often if it's flat and I'm just leisurely moving along.
Re: Camshaft for street 440 [Re: Pacnorthcuda] #2550846
09/17/18 12:01 AM
09/17/18 12:01 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Well the overdrive is only in 5th which i wouldnt plan on going to unless i was cruising at ~60 or above
Re: Camshaft for street 440 [Re: 70charger512] #2552030
09/19/18 06:57 PM
09/19/18 06:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the 528 solid is a good cam. With a set of 1.5 rollers and a tight lash it will have great throttle response. That said you can call and get custom cams all day long for $220. I'd ditch that Performer... not a good intake. FWIW I did a 440 w/ TRW flat tops, ported and bigger valve 915 heads, 528 w/ 1.5 rollers tight lash), headers, and topped it with a six pack...thing ran killer.
Coming soon!!!!
Re: Camshaft for street 440 [Re: Mr.Yuck] #2552083
09/19/18 09:55 PM
09/19/18 09:55 PM
IN
ahy Offline
ahy  Offline
IN
As far as getting rolling from a stop, I think you can do it with either rear. I run the TKO 600 behind a 496 with warm cam (243@.050 intake duration). I can get it rolling OK just above idle with 3.23 rear if I want for street driving. "Driven in anger" I walk it out of the hole at around 2000 RPM with 200 treadwear handling tires and pedal it to prevent smoking the tires.
I am running the .81 OD. if you are running the .7x OD you may want or can get along with higher numerical rear ratio. I think either ratio you are looking at would be fine. It would help to graph speed vs RPM with the two choices to get an idea what might be nicest for your driving plans.
Re: Camshaft for street 440 [Re: GY3] #2553527
09/23/18 09:41 AM
09/23/18 09:41 AM
gregsdart Offline
gregsdart  Offline
Originally Posted By GY3
Originally Posted By pro451bee
I second the MOPAR 528 cam . Changed out a comp XE268 in my 451 earlier this year and very happy. Starts and idles nicer , and way out rips the Comp cam in low and top charge. That Comp cam would always stink at idle and yes just as noisy as the 528 solid .
3rd. Ran it in a 440 in a '71 'cuda. Very good natured and tons of torque!
You can run the 528 and tighten the lash some to quiet the motor if it bugs you. It will make the cam a touch wilder, if you go real tight, like .012 hot. Don't forget, that the lash loosens up as the heads warm up. My 440-1 heads gain .006 lash, RPMs may be a bit less.
Re: Camshaft for street 440 [Re: gregsdart] #2553558
09/23/18 11:13 AM
09/23/18 11:13 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Assuming he's running aluminum heads... smile
Re: Camshaft for street 440 [Re: 70charger512] #2553816
09/23/18 08:35 PM
09/23/18 08:35 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Pretty impressive over on B Bodies with the 30703 Cam on that dyno
Click on link
https://www.forbbodiesonly.com/moparforum/threads/383-to-438-not-too-shabby.159245/
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Page 3 of 3 1 2 3
