Adding a tach but have Pertronix ignition??? #2552976
09/21/18 05:59 PM
09/21/18 05:59 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
I have searched and gotten mixed results online.
I would like to add a tach to my steering column on my 69 Bee. 383/ 4 speed. Using stock coil and ballast resistor.
Some say it won't work properly with Pertronix and others say that theirs functions normally. I am hesitant to just buy a tach and try it as I am not an electronic wiz.
What say you guys? Is there a certain tach I can buy that we know will work properly? I appreciate any help you guys can give. Thank you.
Scott
1969 Super Bee, 383/4 speed
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553022
09/21/18 08:14 PM
09/21/18 08:14 PM
WA
tman Offline
tman  Offline
WA
Have you asked Pertronix? They are pretty responsive to questions, at least for me they have.
Re: Adding a tach but have Pertronix ignition??? [Re: tman] #2553050
09/21/18 09:23 PM
09/21/18 09:23 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Above is the best way to go but I always thought that the stock dash tach's were the one's bothered by Pertronix.
Ron
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553052
09/21/18 09:29 PM
09/21/18 09:29 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just installed a Petronix unit and the factory tach still works.
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553112
09/21/18 11:43 PM
09/21/18 11:43 PM
pass christian, ms
69fish Offline
69fish  Offline
pass christian, ms
I added an autometer tach with my small block with pertronix 1 ignition and it works fine.
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553142
09/22/18 01:32 AM
09/22/18 01:32 AM
Northern NJ
Northern NJ
Thank you for the responses. I have read a bunch, including the Pertronix instruction sheet and like I said, the experiences have varied. No, I haven't called them and that is a great idea.
Thank you!
Scott
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553146
09/22/18 01:53 AM
09/22/18 01:53 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I have a 383 too and had the stock as well as an aftermarket tachometer hooked up and i was running a Pertronix ignition in my distributor so i know it can work! up
Stu
Re: Adding a tach but have Pertronix ignition??? [Re: MidPenMopar] #2553211
09/22/18 12:45 PM
09/22/18 12:45 PM
moparx Online content
moparx  Online Content
using an unknown, imported, tach of questionable quality in my buddy's duster. was working good with points, then i changed over to a pertronix system for him. works as it did before. up
beer
Re: Adding a tach but have Pertronix ignition??? [Re: StukaJU87] #2553240
09/22/18 02:02 PM
09/22/18 02:02 PM
Northern NJ
Northern NJ
Sounds good everyone. Thank you for the feedback!!
Scott
