cordoba front suspension? #2552746
09/21/18 10:43 AM
09/21/18 10:43 AM
G code Jockey Offline OP
did the cordoba, specifically the 80's cars going into the j body, have longitudinal torsion bars like the earlier b bodes or transverse like a diplomat? i cant seem to find much info on these cars. an underbody pic would be great. thanks.
Re: cordoba front suspension? [Re: G code Jockey] #2552761
09/21/18 11:19 AM
09/21/18 11:19 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
what do you mean "going into the J body"?
J body Dobas are all transverse torsion bar setups.
All other body style Cordobas are longitudinal.
Don't be the exception.
Re: cordoba front suspension? [Re: G code Jockey] #2552765
09/21/18 11:31 AM
09/21/18 11:31 AM
is was confused on the issue. thanks for the clearity. i guess i was refering to the j body. i couldnt find anywhere that stated that j body cordobas used the transverse torsion bar system. are these suspenions difficult to work on/modify? i do have experience with the older b body set up for reference.
Re: cordoba front suspension? [Re: G code Jockey] #2552781
09/21/18 12:03 PM
09/21/18 12:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Difficult to work on? No.
You can get performance parts for them
http://www.firmfeel.com/fmj_body_mopar_parts.html
There is some disagreement as to it's abilities to handle at the limits.
I think for anything on the street it can handle as well as the limits of the driver.
If you are junkyard picking later model Diplomats and Gran Furys were used as cop cars, a lot. The fender tag code is AHB they typically have the sorted out HD parts and added handling goodies, like rear sway bars.
Re: cordoba front suspension? [Re: G code Jockey] #2552806
09/21/18 12:35 PM
09/21/18 12:35 PM
does that mean the j/m bodies use interchangable suspension parts? thats good news.
Re: cordoba front suspension? [Re: G code Jockey] #2552807
09/21/18 12:36 PM
09/21/18 12:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
F/M/J suspensions, front and rear, can interchange parts.
Re: cordoba front suspension? [Re: G code Jockey] #2552808
09/21/18 12:37 PM
09/21/18 12:37 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
F, M, J bodies . . . yup interchangable parts
Re: cordoba front suspension? [Re: G code Jockey] #2552941
09/21/18 04:53 PM
09/21/18 04:53 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
The Police Diplomat/Gran Fury had a larger front sway bar if you can find one in yard. Also grab the rear lower spring plate with the bracket for the rear anti sway bar that came on the AHB and the bar and frame bracket too if you can. I know this pic isn't all that helpful, but here's what the bar looks like. I was holding it after removing one I already sold but you can see shape and frame bracket
Facts are stubborn things.
