Replace 590 cam With Roller #2551698
09/18/18 10:30 PM
09/18/18 10:30 PM
Burlington,Ont.
77DragracerR/T Offline OP
Burlington,Ont.
590 cam is gone and a comp XR286 roller goes in with Howards lifters and cam advanced 4* as per degree and running K800 springs. Car is a DOG. Running out of ideas of why?
Comp test 190-195, leak down 4-8%
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551722
09/18/18 11:35 PM
09/18/18 11:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Gonna need a little more info on exactly how it runs different than before.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551728
09/18/18 11:43 PM
09/18/18 11:43 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Isnt that roller a street grind and way smaller than the 590 you took out?
Think the roller is on a 110, the 590 is on a 106. Different animals for sure.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551749
09/19/18 12:21 AM
09/19/18 12:21 AM
gregsdart Offline
gregsdart  Offline
The 590 i believe is 271 degrees at .050,
Much more duration and overlap. It is bound
To hurt power a bunch if the combo worked well with the 590.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551814
09/19/18 06:01 AM
09/19/18 06:01 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
If that’s the 286 solid roller that is not nearly enough spring. I ran 11.00@122 with that cam in a all steel duster with a 408- 10.5, and indybroks. Only 3k converter and 4.10s. That was through full exhaust and @3350 race weight.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551908
09/19/18 12:55 PM
09/19/18 12:55 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
What is the performance difference? What are the track times by comparison, or is this by the butt meter? Two very different cams for sure.
2 kids and a dog
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2551947
09/19/18 02:43 PM
09/19/18 02:43 PM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
The roller looks much smaller in duration 23' less on the intake and 17' on the exhaust side, a little less lift and ground on a 110 instead of the 104.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552169
09/20/18 12:40 AM
09/20/18 12:40 AM
Burlington,Ont.
Burlington,Ont.
Noticed on a history search that FlyFish ran this cam in a 408 Barracuda and had good results. I thought my converter was going as the car slowed each pass by .020
Changed the converter and rechecked the cam degree and advanced it 4* to have the 110.
Last year it ran 11.00@120 with wore out slicks and this year with new slicks was 11.36@118 11.49@117 then the next day was 11.63@115 11.87@112
I'm looking at pulling the motor and put it on a engine dyno and see WTH is going on
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552184
09/20/18 01:20 AM
09/20/18 01:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would be looking at the cam going flat.. unless
you have a bad bearing or so
wave
Re: Replace 590 cam With Roller [Re: MR_P_BODY] #2552476
09/20/18 08:04 PM
09/20/18 08:04 PM
Burlington,Ont.
Burlington,Ont.
Cam is good as I just did the advance of 4* on it and took it to the track. Flat tappet cams yes I'd be at that right away but this change to a roller was to keep from ever going through that again.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552490
09/20/18 08:32 PM
09/20/18 08:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
What’s the motor combo?
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552549
09/20/18 10:30 PM
09/20/18 10:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That cam is 106 ICL, so now you have it @ 102 ? , what ICL is the cam installed ? you said is was at 110 in one of your post,, 110 is the LSA
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552607
09/20/18 11:35 PM
09/20/18 11:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looking at those et’s, I’d be cutting the oil filter open for a look see.
Leak down all the cyls, etc.
If you don’t find anything in the motor, it’s probably the converter.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552644
09/21/18 12:26 AM
09/21/18 12:26 AM
gregsdart Offline
gregsdart  Offline
I'm surprised after reading the on going loss of performance that the rods aren't in the pan or some similar catrstophy hasn't struck. Time for a total disection to see whats going on.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552652
09/21/18 12:44 AM
09/21/18 12:44 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I ran the .590 and loved it! It was faster than the Crane .625 solid roller it replaced. I've read multiple posts about the .590 and it's dated technology. However, I've also read a few posts similar to yours about new cams that don't run as well. I think the .590 purple shaft and the .650 comp are tried and true combinations. Good luck buddy!
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552656
09/21/18 12:52 AM
09/21/18 12:52 AM
AndyF Offline
AndyF  Offline
The 590 cam works really well with the old cast iron heads but might not be such a good choice with something newer like Trick Flow heads. All depends on the combo. No idea on the OP's problem since I don't see enough details to even hazard a guess. Could be anything.
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552661
09/21/18 01:10 AM
09/21/18 01:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
Looking at it from another perspective, if the 590 cam was correct for the motor/car combo, then the XR286R really would really be “too small” to be optimum.
Looking at the OP’s sig says a best of 10.76, I assume that’s the old cam.
Then reports of 11.00 with bald slicks and running the much smaller and milder street roller cam...... which to me bodes well for the XR286R.
And, that’s not even taking into account that it appears “something” in the motor/car is going away.
Re: Replace 590 cam With Roller [Re: AndyF] #2552838
09/21/18 01:43 PM
09/21/18 01:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The .590 cam ran well in my 440 with MCH ported edelbrocks.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2552974
09/21/18 05:55 PM
09/21/18 05:55 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yes, that cam worked unexpectedly well with my 410 combo years ago. Had a best of 10.5 @126mph, but usually ran in the 10.7's.
Sounds like you have other issues unrelated to the cam with it losing mph on every pass...not good. Check the trans, see if you are burning it up (smell the fluid, see if it stinks).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Replace 590 cam With Roller [Re: 77DragracerR/T] #2553033
09/21/18 08:31 PM
09/21/18 08:31 PM
Burlington,Ont.
Burlington,Ont.
My 408 combo is
Scat forged stroker kit, KB744 pistons,Scat forged I beam rods and forged crank
Eddy RPM heads ported and no flow numbers with K800 springs and 1.6 ratio PRW roller rockers
Comp XR286R cam with Howards lifters (no need for oiling mods)
Super Victor Intake and Holley Ultra 850hp
TTI headers
MSD digital 6 and locked dizzy
904 trans,low gear, 4800 J&K converter
4.30 gear with 9" Hoosiers
3420# with driver
When I first built this motor with the 590 cam and had the engine on the dyno it pulled 537hp 540 tq with 750hp carb and TTI headers
We tried a 830hp carb and 1 7/8 headers and it pulled 550/550
The more I think about it the more I think the issue may be in the trans?
