Re: Replace 590 cam With Roller
[Re: 77DragracerR/T]
#2551722
09/18/18 11:35 PM
09/18/18 11:35 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Gonna need a little more info on exactly how it runs different than before.
#2551728
09/18/18 11:43 PM
09/18/18 11:43 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Isnt that roller a street grind and way smaller than the 590 you took out? Think the roller is on a 110, the 590 is on a 106. Different animals for sure.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#2551908
09/19/18 12:55 PM
09/19/18 12:55 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
What is the performance difference? What are the track times by comparison, or is this by the butt meter? Two very different cams for sure.
2 kids and a dog
#2552549
09/20/18 10:30 PM
09/20/18 10:30 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
That cam is 106 ICL, so now you have it @ 102 ? , what ICL is the cam installed ? you said is was at 110 in one of your post,, 110 is the LSA
#2552607
09/20/18 11:35 PM
09/20/18 11:35 PM
fast68plymouth
So. Burlington, Vt.
Looking at those et’s, I’d be cutting the oil filter open for a look see. Leak down all the cyls, etc.
If you don’t find anything in the motor, it’s probably the converter.
#2552661
09/21/18 01:10 AM
09/21/18 01:10 AM
fast68plymouth
So. Burlington, Vt.
Looking at it from another perspective, if the 590 cam was correct for the motor/car combo, then the XR286R really would really be “too small” to be optimum.
Looking at the OP’s sig says a best of 10.76, I assume that’s the old cam. Then reports of 11.00 with bald slicks and running the much smaller and milder street roller cam...... which to me bodes well for the XR286R.
And, that’s not even taking into account that it appears “something” in the motor/car is going away.
[Re: AndyF]
#2552838
09/21/18 01:43 PM
09/21/18 01:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
The 590 cam works really well with the old cast iron heads but might not be such a good choice with something newer like Trick Flow heads. All depends on the combo. No idea on the OP's problem since I don't see enough details to even hazard a guess. Could be anything. The .590 cam ran well in my 440 with MCH ported edelbrocks.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
#2552974
09/21/18 05:55 PM
09/21/18 05:55 PM
Posts: 1,178 Indy
FlyFish
Indy
Noticed on a history search that FlyFish ran this cam in a 408 Barracuda and had good results. I thought my converter was going as the car slowed each pass by .020 Changed the converter and rechecked the cam degree and advanced it 4* to have the 110. Last year it ran 11.00@120 with wore out slicks and this year with new slicks was 11.36@118 11.49@117 then the next day was 11.63@115 11.87@112 I'm looking at pulling the motor and put it on a engine dyno and see WTH is going on Yes, that cam worked unexpectedly well with my 410 combo years ago. Had a best of 10.5 @126mph, but usually ran in the 10.7's. Sounds like you have other issues unrelated to the cam with it losing mph on every pass...not good. Check the trans, see if you are burning it up (smell the fluid, see if it stinks).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
