My Dart is a porker!! #2552006
09/19/18 05:56 PM
09/19/18 05:56 PM
gregsdart Offline OP
Put my 1965 Dart 2dr post car on scales today. Weighs 3115! No driver, 1/2 tank of gas. I was unpleasantly surprised.
Whats in the car; all steel, 408, 904 trans, Ford 8.8 rear, stock back seat, ProCar light weight buckets, no heater or ducts. Coil over and rack and pinion front
Suspension, Wilwood medium street brakes up front, ford discs in back. Full 2 1/2 inch exhaust to th e rear bumper. Motor has iron heads, airgap intake, TTI stepped headers.
15x4 rims and 155r15 tires, 31 lbs each in front. 8.5x18 with 245/45/18 in back, 47.5 lbs each. SS springs.
I was surprised it was that heavy!
56 % weight on front,44% back.
Corner weights, no driver;
Lf 911. Rf 832
Lr 646. Rr 726
Re: My Dart is a porker!! [Re: gregsdart] #2552018
09/19/18 06:22 PM
09/19/18 06:22 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I don't know if I'd call that a porker, but maybe a little more than I would have guessed. smile
2 kids and a dog
Re: My Dart is a porker!! [Re: gregsdart] #2552025
09/19/18 06:40 PM
09/19/18 06:40 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Lf 911. Rf 832
Lr 646. Rr 726
Sounds about right. My little brother has a 66 Dart GT. All steel, full factory interior, Factory buckets and console, no exhaust, just headers, aluminum headed 408, 6 point mild steel cage, s/s springs.
Weighs 3300 with him, he is 240-250 ish
I suspect your exhaust weighs a good bit, probably 60-70 pounds?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My Dart is a porker!! [Re: B3422W5] #2552081
09/19/18 09:53 PM
09/19/18 09:53 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Just weighed this at the track last weekend, it was the super stock, stock combo so they set up scales
with me in car , 3280 .. I weigh 248 lbs frown
all steel , except front bumper .. but, it has aluminum interior and plastic windows ,etc
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: My Dart is a porker!! [Re: gregsdart] #2552086
09/19/18 10:01 PM
09/19/18 10:01 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
All of a sudden, your engines seem to be performing better than anticipated, huh?
[image][/image]
Re: My Dart is a porker!! [Re: bigdad] #2552089
09/19/18 10:04 PM
09/19/18 10:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Sons 1970 Duster is 3200 pounds with him in it at the line (160-170 pounds). Almost as stock equipment as you can get except for a heavy fiberglass 6 pac hood (no other fiberglass). It has caltracs, 8 point cage, frame connectors, stock glass missing wipers and wiper motor, one stock factory bucket seat one race seat, rear seat still in car, factory bumpers and mounts, stock front suspension with only a shock change.
Stock stroke, stock crank 360 that goes 6.54 so probably around a 10.30 in average weather.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My Dart is a porker!! [Re: gregsdart] #2552115
09/19/18 10:58 PM
09/19/18 10:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Weighs the same as my 64 Belvedere.
Doug
Re: My Dart is a porker!! [Re: gregsdart] #2552118
09/19/18 11:03 PM
09/19/18 11:03 PM
Like i mentioned in another post, the plymouth line of early As are shorter, 105.77 inch wheelbase versus 111 inch for my Dart. Other things that add up ; the trunk lid on my Dart is huge and heavy.
I am not sure but i think the 8.8 adds a few pounds as well. John, your sons' car hauls the mail darned good!
Re: My Dart is a porker!! [Re: gregsdart] #2552121
09/19/18 11:08 PM
09/19/18 11:08 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Ha ha we feel your pain. Just scaled our smallblock 904 '65 Dart on the scale at Shakedown at Norwalk last weekend...3195 pounds!
Re: My Dart is a porker!! [Re: gregsdart] #2552124
09/19/18 11:14 PM
09/19/18 11:14 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
2948 at my last scale session including my 200lb self. I think that was with the glass bumper and light brackets, but not sure. Going to scale again if I ever get it running. Have lost 16lb with a hood change, 46lb with a trans change, aluminum driveshaft, rear disc brakes, moved me back 3”. Few other things removed here and there. All glass still factory
Re: My Dart is a porker!! [Re: gregsdart] #2552127
09/19/18 11:17 PM
09/19/18 11:17 PM
PA.
"Little"John
"Little"John
PA.
We found over time Greg that the convertor plays such an important part of the puzzle. I’m sure he’s leaving ET on the table with the 4.10 gears and 727 transmission but it loves a 6400 stall convertor. He just pick up a 742 case set up with a 35 spline spool and 4.56 gears so hopefully we will see how that works out. He hopes to test it before the Halloween Classic
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: My Dart is a porker!! [Re: gregsdart] #2552146
09/20/18 12:02 AM
09/20/18 12:02 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Wow! You all are making me feel good about my 1970 Road Runner.
With me in the drivers seat and 5 gallons of fuel my weights are:
LF 720 RF 715
LR 751 RR 712
Total 2898
The driver is 200 of that. The car is a big block and 727 Dana 60.
No interior, fiberglass everything and lexan for all but the rear windshield. I have split mono leafs and stock front suspension with light weight A arms and aluminum hubs and Wilwood disks.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: My Dart is a porker!! [Re: Digger73] #2552332
09/20/18 02:30 PM
09/20/18 02:30 PM
dogdays Offline
dogdays  Offline
I usually marvel at most Board members when they guess weight of their car, they always guess low.
R.
Re: My Dart is a porker!! [Re: gregsdart] #2552345
09/20/18 03:01 PM
09/20/18 03:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think I have the heavies a-body car lol. 68 Barracuda 3525 with 230lbs driver. Thats with no hood and no back seat! The R1 W2 combo isn't doing it any favors.
68 Barracuda Formula S 340
Re: My Dart is a porker!! [Re: gregsdart] #2552350
09/20/18 03:16 PM
09/20/18 03:16 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Sounds about right. I've seen the effects of weight or the lack of it. Not only on performance, but also the wear and tear on parts. I've gotten to be really anal about weight. And when I see guys do things like throw .134 wall roll cage kits in to save a few bucks or not do easy things to shed pounds, and then spend money to make more power, I just shake my head.
Many years ago, when discussing a new car with Herb McCandless, he told me, and I paraphrese - The best money spent is reducing weight; it doesn't break, it doesn't wear out, it doesn't blow up and you don't have to fix it every winter. I use that philosophy every day.
Re: My Dart is a porker!! [Re: CMcAllister] #2552453
09/20/18 07:17 PM
09/20/18 07:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I hear ya.. my race car is 2400# at the starting line..its
just a bracket car.. I didnt have to have a ton of power
to run quick.. my street rod in my Rampage is 2900# in
full street trim.. both weights are with me in it and a
full tank of fuel.. my Rampage has a 18 gal tank.. both
are easy on parts
Re: My Dart is a porker!! [Re: gregsdart] #2552740
09/21/18 10:34 AM
09/21/18 10:34 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
My barracuda with three gallons of fuel is 3200 without driver. Heater delete, but thats it. They always weigh more than we think!
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: My Dart is a porker!! [Re: gregsdart] #2552868
09/21/18 02:32 PM
09/21/18 02:32 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
TTI's ain't light.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: My Dart is a porker!! [Re: Hemi_Joel] #2552875
09/21/18 02:40 PM
09/21/18 02:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Last time I weighed The MoPig w/ me in it and 1/4 tank fuel, it was 3755 #s on MIR's digital scale.
Since then...
- the Victor heads weigh more than the old Stage VIs
- the Strange S-60 weighs more than the old 8.75
- the modified hood likely picked up some weight
- the driver has probably "found" maybe 30#s, too
I'm fully expecting the next time on a track scale with me in the car, the weight is going to be 38xx...
Re: My Dart is a porker!! [Re: gregsdart] #2553014
09/21/18 08:02 PM
09/21/18 08:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My Charger is 4050 lb with me, talk about a PORKER LOL
