Mezier water pump blows fuse #2550917
09/17/18 07:19 AM
09/17/18 07:19 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I believe its a 150 series, shorter motor. Anybody else have this issue? It happened once before when the impeller came loose. This time that is not the case. Takes about 2 minutes, any amperage fuse. I pulled it out and it runs smooth and quiet. I'm surprised after maybe 10hrs total run time over 6 years.
Doug
Re: Mezier water pump blows fuse [Re: dvw] #2550998
09/17/18 12:08 PM
09/17/18 12:08 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Call Meziere, they have top rate customer service.
My son had a pump about fifteen years and it needed some work. They repaired it and shipped it back the same day they got it.
Re: Mezier water pump blows fuse [Re: dvw] #2551172
09/17/18 06:03 PM
09/17/18 06:03 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Sounds like a bearing is seizing up.
Send it back. Meziere is a great company. You'll have it back in notime.
Re: Mezier water pump blows fuse [Re: dvw] #2551183
09/17/18 06:13 PM
09/17/18 06:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Check the amperage draw with an ammeter. Pump housing getting hot? You are using a relay?
Re: Mezier water pump blows fuse [Re: dvw] #2551271
09/17/18 09:34 PM
09/17/18 09:34 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Just had it all apart. Fans, radiator, pump. Looks perfect, runs smooth. Put it back together, ran about 3 minutes. Wires are warm. Just ordered a new one fro summit. $237 shipped. By the time its sent back I'll bet it's every bit of that. My bet is the motor itself has an issue. I'll call tomorrow and get a quote. Leaving for Indy Thursday.
Doug
Re: Mezier water pump blows fuse [Re: dvw] #2551276
09/17/18 09:50 PM
09/17/18 09:50 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I’m betting you are right and the motor is bad. Something is grounding out. Condensation or a leaky seal allowing water to seep into the case.
Re: Mezier water pump blows fuse [Re: dvw] #2551286
09/17/18 10:21 PM
09/17/18 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug.. check for any loose wire connection..
being that it runs 3 mins under load thats
what I'd look for.. om my Rampage I had the
same issue.. it was a fuse holder.. it was
loose
wave
Re: Mezier water pump blows fuse [Re: dvw] #2551290
09/17/18 10:26 PM
09/17/18 10:26 PM
Minn
SportF Offline
SportF  Offline
Minn
Mine got "fixed" by simply cleaning the commutator. They carbon up after a bit.
Re: Mezier water pump blows fuse [Re: dvw] #2551294
09/17/18 10:32 PM
09/17/18 10:32 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Wiring was checked. When I have time I'll take it apart and see what I can find. You can't pull the armature out of the housing without damaging the seal. I have meeting tomorrow until late. Have to leave Thursday afternoon.
Doug
Re: Mezier water pump blows fuse [Re: dvw] #2551302
09/17/18 10:55 PM
09/17/18 10:55 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Doug I took mine apart between time trials and eliminations at Keystone once. My brushes needed cleaned and I sanded the armiture some. I used a couple of paper clips to hold the brushes back in the brush holders. Small holes were provided for this. Simple fix in my case but yours may be a different issue
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mezier water pump blows fuse [Re: dvw] #2551555
09/18/18 03:53 PM
09/18/18 03:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just send it back to Meziere, I have had a similar issues once before. You might be surprised by your bill...
