Re: Mezier water pump blows fuse
[Re: dvw]
#2551183
09/17/18 06:13 PM
09/17/18 06:13 PM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Check the amperage draw with an ammeter. Pump housing getting hot? You are using a relay?
[Re: dvw]
#2551286
09/17/18 10:21 PM
09/17/18 10:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doug.. check for any loose wire connection.. being that it runs 3 mins under load thats what I'd look for.. om my Rampage I had the same issue.. it was a fuse holder.. it was loose
[Re: dvw]
#2551302
09/17/18 10:55 PM
09/17/18 10:55 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Doug I took mine apart between time trials and eliminations at Keystone once. My brushes needed cleaned and I sanded the armiture some. I used a couple of paper clips to hold the brushes back in the brush holders. Small holes were provided for this. Simple fix in my case but yours may be a different issue
[Re: dvw]
#2551555
09/18/18 03:53 PM
09/18/18 03:53 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Just send it back to Meziere, I have had a similar issues once before. You might be surprised by your bill...
