RacePak user??? #2550430
09/15/18 09:21 PM
09/15/18 09:21 PM
MN
JERICOGTX Offline OP
MN
Pulled the trigger on a Sportsman RacePak. Wondering what everyone keeps track of? My main concern is engine RPM, and driveshaft RPM for clutch slippage.
69 GTX 68 Road Runner
Re: RacePak user??? [Re: JERICOGTX] #2550433
09/15/18 09:34 PM
09/15/18 09:34 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I monitor both G meters voltage . Engine RPM drive shaft rpm. fuel pressure crankcase vacuum O2 s on both sides. And oil pressure.. seems like there's something else I'm. Forgetting
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: RacePak user??? [Re: JERICOGTX] #2550443
09/15/18 10:16 PM
09/15/18 10:16 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
You will want everything. Sensors are addictive. And they are legit. When you have a transmission problem you will look at your pressure etc. I had 22 on the Avenger and wanted more. Now they have tire temp, track temp (I didn't have those). Here is a real life case of why you want sensors. My Neon had fuel pressure for the nitrous system. So if I would have looked at my graph I would have seen that the fuel solenoids weren't opening. There would have been a blip there (or should I say lack of one). I damaged my engine and the Racepak would have saved me.
2011 Drag Pak Challenger
Re: RacePak user??? [Re: rickseeman] #2550463
09/15/18 11:04 PM
09/15/18 11:04 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Idiot me have had mine for over 4 years and never bought a new yoke so I can add my driveshaft sensor.
Oil pressure
Water temp
Trans temp
O2 sensor
Egt added last year
G force
Fuel pressure
May have to add some I forgot to list.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: JERICOGTX] #2550469
09/15/18 11:39 PM
09/15/18 11:39 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
o2,intake air temp,drive shaft,boost and the rest is standard.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: RacePak user??? [Re: JERICOGTX] #2550512
09/16/18 01:23 AM
09/16/18 01:23 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stick car - RPM, input shaft speed, driveshaft speed, Gs are the main ones. I'd like to see shock travel as well.
Re: RacePak user??? [Re: JERICOGTX] #2550626
09/16/18 02:24 PM
09/16/18 02:24 PM
MN
MN
Is the G meter already part of the RacePak? I like the idea of monitoring the oil pressure, and fuel pressure. Any extra advice is greatly appreciated.
Re: RacePak user??? [Re: JERICOGTX] #2550635
09/16/18 02:47 PM
09/16/18 02:47 PM
PA.
"Little"John
"Little"John
PA.
All info is good info but shortly after I bought mine my oil pressure was jumping to 130 pounds PLUS during a pass. If not caught who knows what might have happened. A simple pump change fixed it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: JERICOGTX] #2550636
09/16/18 02:49 PM
09/16/18 02:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. There are several ways of monitoring fuel pressure high pressure at the pump.low pressure after the regulator. I would recommend low pressure after the regulator providing you have a carburetor 0 to 15 psi. Sensor. My cars fuel pressure was all over the board at speed. the race pack really help us tune all the issues out of it car actually picked up quite a bit of ET after I got it squared away
Re: RacePak user??? [Re: JERICOGTX] #2550659
09/16/18 04:18 PM
09/16/18 04:18 PM
hemi-itis Offline
hemi-itis  Offline
RPM,water temp,OP are part of the basic logger.
Re: RacePak user??? [Re: JERICOGTX] #2550695
09/16/18 05:53 PM
09/16/18 05:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I like having driveshaft or wheel speed data. I would also like a G force meter, that is one of things Scott Brown used to make such big strides with Capone on drag week. He changed his shift point based on data from the g-meter and picked up .1.
68 Barracuda Formula S 340
Re: RacePak user??? [Re: Bad340fish] #2550755
09/16/18 08:40 PM
09/16/18 08:40 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Are you running the dash unit Jeff?
Alan Jones
Re: RacePak user??? [Re: LA360] #2550762
09/16/18 08:49 PM
09/16/18 08:49 PM
MN
MN
No. Not much of a fan of that look. Trying to keep the car looking old school. I'll most likely hide the Racepack somewhere it's not too obvious, but yet I can access it easily.
Re: RacePak user??? [Re: LA360] #2550763
09/16/18 08:54 PM
09/16/18 08:54 PM
PA.
"Little"John
"Little"John
PA.
Just something I will add. I bought the sportsman model and the display dash. About 1 1/2 years later my dash lights dimmed and are worthless. 2 years later I am still needing a flashlight to monitor my engine temps while in the staging lanes at night. If I remember right when I called I think he said it would be around 150-200.00 to repair it. I would never pay to hat much to repair it and I will not be putting the dash readout in my heads up car. I may try to fix it myself this winter while freshening the engine.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: JERICOGTX] #2550852
09/17/18 12:25 AM
09/17/18 12:25 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
RacePak also has analog gauges which are pretty bitchen. No temp. or pressure sensors in the package. G's, rpm, driveshaft rpm and a 12V event. Most cars I've seen have them mounted flat about midway up in the car. I mounted mine flat and low in the car because my car is, well, low...Call Figspeed for good prices and on track knowledge on the sensors.
Re: RacePak user??? [Re: Dave Hall] #2550862
09/17/18 12:40 AM
09/17/18 12:40 AM
PA.
"Little"John
"Little"John
PA.
Prices are pretty price controlled so I bought my second one with a 10% off Summit coupon
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: RacePak user??? [Re: JERICOGTX] #2550901
09/17/18 03:20 AM
09/17/18 03:20 AM
hemi-itis Offline
hemi-itis  Offline
I have the logger dash.
Re: RacePak user??? [Re: pittsburghracer] #2550954
09/17/18 10:53 AM
09/17/18 10:53 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I just bought the IQ3 Logger Drag dash.
I liked that the SD card is handy to get to on the face.
It comes with oil pres. and water temp sensors.
"Just a Bracket car dressed up like a streetcar"
Re: RacePak user??? [Re: JERICOGTX] #2551045
09/17/18 01:50 PM
09/17/18 01:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You might consider an EFI controller to run your igntion system, it will also datalog anything and everything you could want and not be tied to special racepak $ensors.
Re: RacePak user??? [Re: pittsburghracer] #2551054
09/17/18 02:04 PM
09/17/18 02:04 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Just sent mine in for backlight issue and I was told $60 plus shipping. Should be back this week.
