RacePak user???
#2550430
09/15/18 09:21 PM
09/15/18 09:21 PM
Posts: 10,021 MN
JERICOGTX
MN
Pulled the trigger on a Sportsman RacePak. Wondering what everyone keeps track of? My main concern is engine RPM, and driveshaft RPM for clutch slippage.
69 GTX
68 Road Runner
Re: RacePak user???
[Re: JERICOGTX]
#2550433
09/15/18 09:34 PM
09/15/18 09:34 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I monitor both G meters voltage . Engine RPM drive shaft rpm. fuel pressure crankcase vacuum O2 s on both sides. And oil pressure.. seems like there's something else I'm. Forgetting
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: RacePak user???
[Re: JERICOGTX]
#2550443
09/15/18 10:16 PM
09/15/18 10:16 PM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You will want everything. Sensors are addictive. And they are legit. When you have a transmission problem you will look at your pressure etc. I had 22 on the Avenger and wanted more. Now they have tire temp, track temp (I didn't have those). Here is a real life case of why you want sensors. My Neon had fuel pressure for the nitrous system. So if I would have looked at my graph I would have seen that the fuel solenoids weren't opening. There would have been a blip there (or should I say lack of one). I damaged my engine and the Racepak would have saved me.
2011 Drag Pak Challenger
Re: RacePak user???
[Re: rickseeman]
#2550463
09/15/18 11:04 PM
09/15/18 11:04 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Idiot me have had mine for over 4 years and never bought a new yoke so I can add my driveshaft sensor.
Oil pressure Water temp Trans temp O2 sensor Egt added last year G force Fuel pressure May have to add some I forgot to list.
Re: RacePak user???
[Re: JERICOGTX]
#2550512
09/16/18 01:23 AM
09/16/18 01:23 AM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stick car - RPM, input shaft speed, driveshaft speed, Gs are the main ones. I'd like to see shock travel as well.
Re: RacePak user???
[Re: JERICOGTX]
#2550626
09/16/18 02:24 PM
09/16/18 02:24 PM
Posts: 10,021 MN
JERICOGTX
MN
Is the G meter already part of the RacePak? I like the idea of monitoring the oil pressure, and fuel pressure. Any extra advice is greatly appreciated.
69 GTX
68 Road Runner
Re: RacePak user???
[Re: JERICOGTX]
#2550635
09/16/18 02:47 PM
09/16/18 02:47 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is the G meter already part of the RacePak? I like the idea of monitoring the oil pressure, and fuel pressure. Any extra advice is greatly appreciated. All info is good info but shortly after I bought mine my oil pressure was jumping to 130 pounds PLUS during a pass. If not caught who knows what might have happened. A simple pump change fixed it.
Re: RacePak user???
[Re: JERICOGTX]
#2550636
09/16/18 02:49 PM
09/16/18 02:49 PM
WHITEDART
bean town ....Ca
Is the G meter already part of the RacePak? I like the idea of monitoring the oil pressure, and fuel pressure. Any extra advice is greatly appreciated. . There are several ways of monitoring fuel pressure high pressure at the pump.low pressure after the regulator. I would recommend low pressure after the regulator providing you have a carburetor 0 to 15 psi. Sensor. My cars fuel pressure was all over the board at speed. the race pack really help us tune all the issues out of it car actually picked up quite a bit of ET after I got it squared away
Re: RacePak user???
[Re: JERICOGTX]
#2550695
09/16/18 05:53 PM
09/16/18 05:53 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I like having driveshaft or wheel speed data. I would also like a G force meter, that is one of things Scott Brown used to make such big strides with Capone on drag week. He changed his shift point based on data from the g-meter and picked up .1.
68 Barracuda Formula S 340
Re: RacePak user???
[Re: LA360]
#2550762
09/16/18 08:49 PM
09/16/18 08:49 PM
Posts: 10,021 MN
JERICOGTX
MN
Are you running the dash unit Jeff? No. Not much of a fan of that look. Trying to keep the car looking old school. I'll most likely hide the Racepack somewhere it's not too obvious, but yet I can access it easily.
69 GTX
68 Road Runner
Re: RacePak user???
[Re: LA360]
#2550763
09/16/18 08:54 PM
09/16/18 08:54 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just something I will add. I bought the sportsman model and the display dash. About 1 1/2 years later my dash lights dimmed and are worthless. 2 years later I am still needing a flashlight to monitor my engine temps while in the staging lanes at night. If I remember right when I called I think he said it would be around 150-200.00 to repair it. I would never pay to hat much to repair it and I will not be putting the dash readout in my heads up car. I may try to fix it myself this winter while freshening the engine.
Re: RacePak user???
[Re: Dave Hall]
#2550862
09/17/18 12:40 AM
09/17/18 12:40 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Prices are pretty price controlled so I bought my second one with a 10% off Summit coupon
Re: RacePak user???
[Re: pittsburghracer]
#2550954
09/17/18 10:53 AM
09/17/18 10:53 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I just bought the IQ3 Logger Drag dash. I liked that the SD card is handy to get to on the face.
It comes with oil pres. and water temp sensors.
"Just a Bracket car dressed up like a streetcar"
Re: RacePak user???
[Re: JERICOGTX]
#2551045
09/17/18 01:50 PM
09/17/18 01:50 PM
Bad340fish
Tulsa OK
You might consider an EFI controller to run your igntion system, it will also datalog anything and everything you could want and not be tied to special racepak $ensors.
