How to hook up this pressure switch mpl-808 #2550173
09/15/18 01:41 AM
09/15/18 01:41 AM
IL
furious70 Offline OP
IL
https://lh3.googleusercontent.com/NJx8_D...6I=w443-h910-no
The electrical hookup, 3 connectors on it, what goes to what? Their engineering diagram doesn't talk about the electrical connectors
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to hook up this pressure switch mpl-808 [Re: furious70] #2550299
09/15/18 01:41 PM
09/15/18 01:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Can't open your link but the 3 connectors are usually *Normally Open, *Normally Closed and *Common.
Re: How to hook up this pressure switch mpl-808 [Re: furious70] #2550311
09/15/18 02:11 PM
09/15/18 02:11 PM
IL
IL
Makes sense but I can't see any marking on them to know which is which, will just have to try I guess
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to hook up this pressure switch mpl-808 [Re: furious70] #2550313
09/15/18 02:14 PM
09/15/18 02:14 PM
IL
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to hook up this pressure switch mpl-808 [Re: furious70] #2550345
09/15/18 04:39 PM
09/15/18 04:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Use a multi-meter or test light to check for continuity between two terminals without vacuum and then with vacuum; one terminal will be common to both.
