What's going on with my clutch?
#2549698
09/13/18 05:26 PM
09/13/18 05:26 PM
Posts: 1,121 State, country, etc.
gss
My A833 won't shift into gear while the car is running unless the back tires are off the ground. Even then it is a little difficult. This is a car that worked great when put in storage in 1991. It has a fresh 440. The original pressure plate was rebuilt. The original aluminum flywheel was resurfaced. The disc is a new. The new crankshaft probably came from an automatic car so I used the pilot bearing for conversion to 4 speed. It did take a little more jostling than usual to get the engine to mate with the transmission. I even took an extra input shaft and made sure it fit in the clutch splines and pilot bearing. It eventually went together fine. I don't think the trans developed a problem from sitting a long time. Could the pilot bearing be grabbing the input shaft somehow? With the back tires off the ground and the clutch disengaged in 4th gear, I can see the clutch disc spin freely when someone turns the back tires. I have a good view of the throwout bearing and that seems fine. What am I missing?
Re: What's going on with my clutch?
[Re: gss]
#2549728
09/13/18 07:18 PM
09/13/18 07:18 PM
Posts: 25,991 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Even though the disc spins freely with the pedal depressed, it might not have enough clearance when running; use a feeler gauge to check the air gap with the pedal fully depressed, .060" minimum.
[Re: gss]
#2549736
09/13/18 07:36 PM
09/13/18 07:36 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
In no particular order.
1 bellhousing not aligned to block. Are the block and bell original to each other?
2. Pilot hole in crank not deep enough.
3. Sometimes rebuilt pressure plates are not set properly so that the plate is not parrelel to the flywheel causing one side to drag.
4. Pilot bearing might need to be reamed.
[Re: John_Kunkel]
#2549778
09/13/18 10:39 PM
09/13/18 10:39 PM
gss
Even though the disc spins freely with the pedal depressed, it might not have enough clearance when running; use a feeler gauge to check the air gap with the pedal fully depressed, .060" minimum. My eyeball says it was well over 0.080" but I will measure it. Thanks
[Re: GomangoCuda]
#2549781
09/13/18 10:58 PM
09/13/18 10:58 PM
gss
4. Pilot bearing might need to be reamed. 1. They are not original to each other. The bell is not aftermarket. 2. I checked this before assembly but didn't make notes. The input shaft seems to spin freely when the car is on jacks and I am turning the back tires in 4th. 3. Possible. I will check. The clutch shop here is usually pretty good. 4. Its not a bushing. I did fit it over the input shaft before driving it into the crank. It does seem to spin fine in the bearing.
[Re: gss]
#2549944
09/14/18 01:11 PM
09/14/18 01:11 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Those are interesting symptoms.
Here's a quick and easy way to verify that your transmission input shaft is not bottoming out in the crank's pilot hole.
Try loosening the 4 bolts that hold the transmission to the bell housing and see if the transmission moves back by itself. If a gap opens up between the trans and the bellhousing, you likely will have to cut/shorten the input shaft.
I had to shorten the input shaft on my 833 to allow it clearance from the bottom of the pilot hole in the crank.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2549996
09/14/18 03:27 PM
09/14/18 03:27 PM
gss
I had to shorten the input shaft on my 833 to allow it clearance from the bottom of the pilot hole in the crank. Good idea. Although I would expect they separate slightly. If a 0.030" gap opens up, is that a positive result? How much fore/aft play is in the input shaft? Maybe a better test would be to loosen the bellhousing bolts so the bell can move back 0.060-0.080", not enough that the starter wouldn't engage or come out of its pilot hole, and start it up to see if it shifts better. Now that would be a positive result. Any reason that wouldn't work?
[Re: gss]
#2550072
09/14/18 07:39 PM
09/14/18 07:39 PM
John_Kunkel
Rio Linda, CA
When you observed the clutch disc turning freely when the rear wheels were spun, you have a leverage advantage; put the trans in Neutral, have somebody fully depress the clutch pedal and push on the disc with a screwdriver to see if it turns freely.
[Re: gss]
#2550112
09/14/18 09:50 PM
09/14/18 09:50 PM
GomangoCuda
1 bellhousing not aligned to block. Are the block and bell original to each other? 1. They are not original to each other. The bell is not aftermarket The factory bell is machined bolted to its block. If you put it on a different block it may need offset dowels to get it concentric with the crank. May or may not be your problem. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: GomangoCuda]
#2550117
09/14/18 10:06 PM
09/14/18 10:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The factory bell is machined bolted to its block. If you put it on a different block it may need offset dowels to get it concentric with the crank. May or may not be your problem. lol, never heard that one before.
[Re: gss]
#2550139
09/14/18 11:30 PM
09/14/18 11:30 PM
Supercuda
About to go away
About to go away
up yours
Kunkel says a lot of things. No proof though.
[Re: Supercuda]
#2550158
09/15/18 12:28 AM
09/15/18 12:28 AM
GomangoCuda
Please explain why Factory Service Manuals say that a replacement bellhousing must be dialed in and corrected with offset dowels.
[Re: John_Kunkel]
#2550170
09/15/18 01:12 AM
09/15/18 01:12 AM
gss
When you observed the clutch disc turning freely when the rear wheels were spun, you have a leverage advantage; put the trans in Neutral, have somebody fully depress the clutch pedal and push on the disc with a screwdriver to see if it turns freely. Okay we did that and I could not budge the clutch disc. I was able to get a 0.064" feeler gauge between the disc and pressure plate but the disc seemed to be tight against the flywheel. When observing the clutch as the pedal is depressed, I noticed that the disc moves away from the flywheel briefly but then settles down against the flywheel almost immediately.
[Re: Supercuda]
#2550291
09/15/18 01:22 PM
09/15/18 01:22 PM
John_Kunkel
Rio Linda, CA
Kunkel says a lot of things. No proof though. You can lead a horse to water but.............
[Re: gss]
#2550351
09/15/18 04:57 PM
09/15/18 04:57 PM
GomangoCuda
When you observed the clutch disc turning freely when the rear wheels were spun, you have a leverage advantage; put the trans in Neutral, have somebody fully depress the clutch pedal and push on the disc with a screwdriver to see if it turns freely. Okay we did that and I could not budge the clutch disc. I was able to get a 0.064" feeler gauge between the disc and pressure plate but the disc seemed to be tight against the flywheel. When observing the clutch as the pedal is depressed, I noticed that the disc moves away from the flywheel briefly but then settles down against the flywheel almost immediately. Did you check that gap at more than one place? Pressure plate probably still against the disc 180 degrees from there. If so it's broke.
[Re: GomangoCuda]
#2550670
09/16/18 04:50 PM
09/16/18 04:50 PM
John_Kunkel
Rio Linda, CA
Sometimes the clutch disc splines are tight on the shaft, some clutch kits supply spline lubricant to avoid that.
[Re: gss]
#2550758
09/16/18 08:41 PM
09/16/18 08:41 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
What order did this happen? Was it put away working after the engine and clutch work? As for the offset dowels. I've checked a few and since I like to get chase things to the middle of their acceptable range. The fact is I've never seen a difference from out of spec to middle of the spec as far as shift quality, clutch engagement etc. GSS's problem is not something offset dowels will fix. Here is a pressure plate with air gap but it can not be put into gear. There is a major drag from the engine to the input shaft or clutch disc. I'd like to 1st confirm the input shaft is not bottomed out in the automatic crankshaft. How about loosening the transmission to bellhousing bolts. Moving the transmission back a 1/4" and check again. If this idea worries you, sandwich something in there and snug the bolts up.
