Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2548223
09/10/18 01:50 AM
09/10/18 01:50 AM
eastern L.I. ,NYC
K
kingdragon Offline
kingdragon  Offline
K
eastern L.I. ,NYC
A Chinese replacement part that doesn't even come close to fitting?
Shocking!
I only buy MADE IN USA.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2548410
09/10/18 03:12 PM
09/10/18 03:12 PM
Chicago
PurpleBeeper Offline
Chicago
I ran into a similar issue with my Champion using an OEM-style plastic reproduction shroud. I trimmed the shroud up pretty good and made some mounting tabs out of sheet metal & some pop rivets. It took quite a bit of "fabricating" to get everything to line up right. The hardware store window sealing foam tape is a really good idea.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Centerline] #2549217
09/12/18 02:37 PM
09/12/18 02:37 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Originally Posted By Centerline
Its amazing how people love to spend other people's money..... which is fine if you are independently rich. grin
I’m not spending his money either. Nor am I independently rich.
I see it all the time. Guy buys a Champion, then complains about fit, quality, and what has to be modified to make it all work.
Griffins drop in like stock, fit, and accept a stock shroud. They also mimick a stock appearance so if painted black it’ll look factory to the casual observer. Spend a little more up front to avoid disappointment later.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: bill440rt] #2549562
09/13/18 12:14 PM
09/13/18 12:14 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Originally Posted By bill440rt
I’m not spending his money either. Nor am I independently rich. I see it all the time. Guy buys a Champion, then complains about fit, quality, and what has to be modified to make it all work. Griffins drop in like stock, fit, and accept a stock shroud. They also mimick a stock appearance so if painted black it’ll look factory to the casual observer. Spend a little more up front to avoid disappointment later.
There is nothing wrong with Champion radiators. They cool just fine. However, they are an aftermarket item not OEM nor do they claim to be. So some slight modification may be needed for them to fit perfectly. Mine needed one hole elongated slightly which took all of two minutes with a file to fix.
The point is that most inexpensive aftermarket radiators are going to require some level of work for everything to fit the way it should. For what a Griffin or Walker replacement costs you can buy two Champion radiators and you can buy about 6 Champions for the price of a Glen Ray replacement. They're all excellent quality, drop in and OEM shrouds fit perfectly. However, for me and a lot of other people who don't have unlimited budgets, it very often makes sense to spend a little extra work to save a considerable amount of money in the end.
Champions cool fine if set up properly but anyone who purchases aftermarket parts needs to understand that some level of modification may be required. Many parts of this type are mass produced and designed to be "generic" so naturally they will require some fitting. Anyone who buys one is a little naive if they think its just going to drop in.... and that's true of a lot of aftermarket parts.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2549574
09/13/18 12:49 PM
09/13/18 12:49 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Lindy, by chance will the OEM shroud fit (slide down into/ EDIT: or up into) to the inside of the brackets, as opposed to the outside??? It looks a little thick, but I ain't there to measure...
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2549581
09/13/18 01:12 PM
09/13/18 01:12 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
FYI, i have a Champion radiator on my car and it has the shroud mounts like in the first post. Well that radiator is leaking just a bit (was on the car when i got it, core is 3 row looks like brass but sure that is right..).
anyway, i bought a 2 row (Alum core) 26" Champion about 8 years ago thinking i would need it for my truck, never used it. I just checked it to see if it is the same as what is in my car and the mounts for the shroud are flush with the core, so they must've changed their design years back...
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: krautrock] #2549597
09/13/18 01:34 PM
09/13/18 01:34 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Just looking at the pictures that shroud is way too far back and covering most of the fan, not a good way to cool and engine for sure. The shroud needs to be as flush to the radiator as possible, the fan needs to be 3/4" from the radiator, and sticking out of the shroud for maximum effect. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2549614
09/13/18 02:05 PM
09/13/18 02:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Too many cases of Champion radiators being bent, or leaking or fitment issues for me to say "There is nothing wrong with Champion radiators" and hiding behind "it's aftermarket, of course it will need fitment" is BS. Especially when it's not a universal fit but rather "3 core Champion 26" replacement radiator". Replacement implies it fits like stock, not fits like universal but you pay the replacement upcharge for it.
Don't be the exception.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: bill440rt] #2549655
09/13/18 03:42 PM
09/13/18 03:42 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I have no love affair with Champion, but Griffins are 3 times the price. Not a little more. Glen Ray is 4 times as much. I don’t hear Champion owners complaining about the performance. Not even me. FINISH quality is not great, but BUILD quality is fine and when you build a car on a 33% budget you make your choices. I spent my money on other parts.
On a positive note, here’s what I’ve done with a piece of 1”x 1/16” aluminum bar stock. I’ll add a high-density foam rubber garage door seal lip underneath to seal the gap and rivet it on to some hand shaped L brackets. So goes hotrodding.
...and not bad for a guy with no access to a metal shop. 😊
Without
With
I’m listening.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Fat_Mike] #2549664
09/13/18 03:54 PM
09/13/18 03:54 PM
Spokane Valley, WA
Spokane Valley, WA
Mike, I thought long and hard about doing that. I’d have to cut the mating surface of the shroud completely off where the bolts go because they are offset. Also, the radiator has brass nut inserts that I’d have to extract. One of those cases where I wish I’d known I was going with the part (shroud) ahead of time so that I could have fabbed it on the bench. Thank you for the suggestion.
I’m listening.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Rhinodart] #2549668
09/13/18 04:03 PM
09/13/18 04:03 PM
Spokane Valley, WA
Spokane Valley, WA
Excellent point. The fan is in there but it’s not bolted in. The blades protrude about 1/2” maybe a little less than half way out of the shroud when it’s sitting against its mounting surface. Not sure if that’s enough. Also, it is a 5 blade fan with clutch. Do you think that’s enough blade? Would it do better to remove the clutch to get the fan further back?
I’m listening.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2549852
09/14/18 03:55 AM
09/14/18 03:55 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Picture of mine, 70 Charger with a 408 small block. I took the top half of the shroud off, to replace the fan belts. And left it off. Never overheats, and Florida gets hot....
The fan is quite close to the radiator.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2550181
09/15/18 02:09 AM
09/15/18 02:09 AM
Spokane Valley, WA
Spokane Valley, WA
I think I'm going to change my screen name to "Cricket"...
...because that's all I hear after I post.
I’m listening.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2550281
09/15/18 12:58 PM
09/15/18 12:58 PM
Looks good! that's one of my weakest areas is metal fab
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2550865
09/17/18 12:46 AM
09/17/18 12:46 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
and the other is a new fangle cell phone? LOL
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: mopars4ever] #2550872
09/17/18 01:05 AM
09/17/18 01:05 AM
Yes! I have yet to figure out how to dial a # on it but I am streaming music into my mini shop so I am happy.
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2551399
09/18/18 09:57 AM
09/18/18 09:57 AM
STL
cdstl Offline
cdstl  Offline
STL
Without
With
BB Bee
Your over your private topic limit and I tried to send you a PM. Where did you find the aluminum bar stock? I would like to duplicate what you've done.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Champion Radiator and Stock Fan Shroud Issues. Ideas Please [Re: Big Bad Bee] #2551502
09/18/18 02:04 PM
09/18/18 02:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ace Hardware sells sticks of aluminum like that in a number of different widths and thicknesses.
