Brake Anomaly
#2548810
09/11/18 03:05 PM
09/11/18 03:05 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My '57 Dodge has upgraded manual brakes, later rear with drum brakes and front disc conversion using a factory tandem MC. After the conversion I bench bled the new MC and thoroughly bled the system and had a good firm pedal. I've been driving it occasionally with no brake problems.
So, the other day I jump in and back it out of the garage, apply the brakes and the pedal is way low and spongy. I check the fluid level and look for signs of a leak; fluid level is correct and no leaks.
I have a friend operate the brake pedal while I observe the fluid in the reservoir, rear reservoir shows a normal slight burble in the fluid surface as the pedal is applied but the front reservoir (for the rear drum brakes) has air bubbles rising. Slowly pumping the pedal produces rising air bubbles with each stroke. So, today I sat in the car and slowly pumped the brake pedal numerous times and now the pedal feel is just like it was before the incident.
I'm at a loss to figure where the air in the front reservoir came from, the MC has no RPV so I installed one (10 psi) in the line to the rear brakes. How can air suddenly appear in a system that's sealed tight? Any thoughts?
Re: Brake Anomaly
[Re: Andrewh]
#2548910
09/11/18 06:18 PM
09/11/18 06:18 PM
John_Kunkel
Rio Linda, CA
Fluid level remains the same, all rubber hoses are brand new and dry.
Re: Brake Anomaly
[Re: John_Kunkel]
#2548933
09/11/18 06:56 PM
09/11/18 06:56 PM
RapidRobert
I'm at a loss to figure where the air in the front reservoir came from. How can air suddenly appear in a system that's sealed tight? Any thoughts? I'm thinking a loose fitting/line/hose that is allowing air to be sucked back up in there on the return stroke.
Re: Brake Anomaly
[Re: John_Kunkel]
#2548934
09/11/18 07:04 PM
09/11/18 07:04 PM
RapidRobert
Slowly pumping the pedal produces rising air bubbles with each stroke. Yeah either the air is still in there (& I wouldn't think so as there ain't no magic to bleeding) & especially with the amt of the bubbles (from what it sounds like) that it (air) is being drawn back in somehow.
Re: Brake Anomaly
[Re: John_Kunkel]
#2548939
09/11/18 07:19 PM
09/11/18 07:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One thing we learned in the Navy was that watertight did not mean airtight.
IOW, air leaks in easier than a liquid. Probably woulcn't hurt to put a wrench on all connections and retighten them.
Re: Brake Anomaly
[Re: John_Kunkel]
#2549113
09/12/18 04:45 AM
09/12/18 04:45 AM
Posts: 20,652 in a cattle trailer down by th...
Guitar Jones
The air most likely came in from a wheel cylinder.
Re: Brake Anomaly
[Re: Guitar Jones]
#2549257
09/12/18 03:58 PM
09/12/18 03:58 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
The air most likely came in from a wheel cylinder. This ^^^^^^ I have had this happen more than once, also VERY common on c3 vett calipers to suck air
Re: Brake Anomaly
[Re: Guitar Jones]
#2549295
09/12/18 05:44 PM
09/12/18 05:44 PM
John_Kunkel
Rio Linda, CA
The air most likely came in from a wheel cylinder. The RPV is supposed to prevent that. The notion that the air was always there, trapped somehow, isn't consistent with the pedal being firm after the original installation.
