Squealing fan belt #2548374
09/10/18 01:48 PM
09/10/18 01:48 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
WHat is the best way to cure a squealing fan belt? My fan belt doesn't squeal when idling or accelerating while driving, but squeals loudly if I rev the engine while idling in park. The belt is fairly new and the pulleys are aligned properly. No power steering so it's only driving the water pump and alternator. The belt feels like it has the right amount of tension on it as well but could it maybe need a little more tension/slack?
Re: Squealing fan belt [Re: 1970RT] #2548385
09/10/18 02:05 PM
09/10/18 02:05 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can media blast the pulley grooves to restore some texture to them, it will help dramatically. It's an often overlooked but effective step in set-up.
I've also used some 120 to 150 grit Emory cloth to cut the shine from the pulley grooves, which gives the belts some bite.
If you have just changed the belt, lightly scuff any shine off it with the same paper, then clean well and reinstall.
Use quality belts and be sure to tension properly.
I've made special belt tensioning tools out of turnbuckles with welded "T"'s on the ends of the bolts to fit securely in the "V" grooves to aid in getting the belts tensioned properly.
Re: Squealing fan belt [Re: 1970RT] #2548391
09/10/18 02:26 PM
09/10/18 02:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Are the pulleys powdercoated? is the belt oversized in width?, meaning it's not sitting down in the groove far enough?, these things can contribute to a squealing belt
Re: Squealing fan belt [Re: 1970RT] #2548393
09/10/18 02:28 PM
09/10/18 02:28 PM
P
Porter67 Offline
Porter67  Offline
P
Napa has belt dressing, you cant see it and it leaves no residue.
Just gives the belt a bit more grip and lasts a long time.
The worst thing on our old junk is over tightening.
https://www.napaonline.com/p/MCR1397
Re: Squealing fan belt [Re: Porter67] #2548461
09/10/18 05:07 PM
09/10/18 05:07 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Overtightening can ruin the alternator. Been there, done that.
Re: Squealing fan belt [Re: 1970RT] #2548499
09/10/18 06:53 PM
09/10/18 06:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Make sure you have the correct width fan belt. Too narrow or too wide can cause problems. Is it a Quanta Belt?
Re: Squealing fan belt [Re: DAYCLONA] #2548614
09/11/18 12:55 AM
09/11/18 12:55 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Cogged belt?
Ed
Re: Squealing fan belt [Re: Mr. Smurf] #2548707
09/11/18 11:33 AM
09/11/18 11:33 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Dry bar of soap rubbed on the sides of the belt should cure it. It's not a cure-all for being too loose, or the wrong belt.
Re: Squealing fan belt [Re: Neil] #2548717
09/11/18 11:49 AM
09/11/18 11:49 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Soap does sometimes work, but I have had better luck by rubbing a candle on the belt. If there are no overriding problems, the wax will quiet the squeal.
Master, again and still
Re: Squealing fan belt [Re: DaveRS23] #2548758
09/11/18 01:25 PM
09/11/18 01:25 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Pulleys wear out over time. If the pulley is worn the belt wont sit in the groove correctly. There are pulley gauges available to verify the pulleys are good.
Re: Squealing fan belt [Re: 1970RT] #2550765
09/16/18 09:00 PM
09/16/18 09:00 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Sounds like a responsive 440 with a engine driven fan. It is basically a challenging thing to overcome.
