Re: Squealing fan belt
[Re: 1970RT]
#2548385
09/10/18 02:05 PM
09/10/18 02:05 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
You can media blast the pulley grooves to restore some texture to them, it will help dramatically. It's an often overlooked but effective step in set-up.
I've also used some 120 to 150 grit Emory cloth to cut the shine from the pulley grooves, which gives the belts some bite.
If you have just changed the belt, lightly scuff any shine off it with the same paper, then clean well and reinstall.
Use quality belts and be sure to tension properly.
I've made special belt tensioning tools out of turnbuckles with welded "T"'s on the ends of the bolts to fit securely in the "V" grooves to aid in getting the belts tensioned properly.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 1970RT]
#2548391
09/10/18 02:26 PM
09/10/18 02:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
WHat is the best way to cure a squealing fan belt? My fan belt doesn't squeal when idling or accelerating while driving, but squeals loudly if I rev the engine while idling in park. The belt is fairly new and the pulleys are aligned properly. No power steering so it's only driving the water pump and alternator. The belt feels like it has the right amount of tension on it as well but could it maybe need a little more tension/slack? Are the pulleys powdercoated? is the belt oversized in width?, meaning it's not sitting down in the groove far enough?, these things can contribute to a squealing belt
[Re: 1970RT]
#2548393
09/10/18 02:28 PM
09/10/18 02:28 PM
Porter67
Napa has belt dressing, you cant see it and it leaves no residue. Just gives the belt a bit more grip and lasts a long time. The worst thing on our old junk is over tightening. https://www.napaonline.com/p/MCR1397
[Re: Neil]
#2548717
09/11/18 11:49 AM
09/11/18 11:49 AM
Posts: 12,226 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Soap does sometimes work, but I have had better luck by rubbing a candle on the belt. If there are no overriding problems, the wax will quiet the squeal.
Master, again and still
