LA heads on a magnum block? #2546985
09/06/18 11:54 PM
09/06/18 11:54 PM
michigan
6pakdakota Offline OP
michigan
I am beginning to gather parts for a mild 360 build for my 85 D150. It will be based off of a stock 360 magnum short block. I am thinking about running an aftermarket la head if possible and was wondering if the hole circled in the photo below is the oil feed hole for the rockers on la style heads? The block I am using is a 94, if that matters.
Re: LA heads on a magnum block? [Re: 6pakdakota] #2547004
09/07/18 12:40 AM
09/07/18 12:40 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
thats the one you need
Re: LA heads on a magnum block? [Re: HotRodDave] #2547028
09/07/18 01:31 AM
09/07/18 01:31 AM
michigan
michigan
Awesome. Thank you.
Re: LA heads on a magnum block? [Re: 6pakdakota] #2547055
09/07/18 03:30 AM
09/07/18 03:30 AM
Lucky for you you have an early mag block with LA oiling.
Re: LA heads on a magnum block? [Re: 6pakdakota] #2547471
09/08/18 02:53 AM
09/08/18 02:53 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
blow air thru the hole on block deck to ensure it is fully drilled to cam bearing...
Tony
70 AARCuda Vitamin C
Re: LA heads on a magnum block? [Re: 6pakdakota] #2547882
09/09/18 12:12 PM
09/09/18 12:12 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Don't forget when calculating cr, the deck height is 9.585 compared to 9.599 on a LA block...it changes pushrods lenght too
Dan
Re: LA heads on a magnum block? [Re: Wedgeman] #2548390
09/10/18 02:22 PM
09/10/18 02:22 PM
dogdays Offline
dogdays  Offline
Published spec for late model LAs is 9.577 - 9.578. Did they change it going to the Mag engine?
R.
Re: LA heads on a magnum block? [Re: 6pakdakota] #2548496
09/10/18 06:50 PM
09/10/18 06:50 PM
W
Wedgeman Offline
Wedgeman  Offline
W
To my knowledge, all LA were 9.599 tall....for sure 94-95 mags were 9.585...
Went trough a couple of blocks to confirm, may be DusterDave could confirm too
Dan
Re: LA heads on a magnum block? [Re: 6pakdakota] #2550204
09/15/18 07:15 AM
09/15/18 07:15 AM
gregsdart Offline
gregsdart  Offline
My Magnum block had to be cut to 9.577 to square it up,,,,,,,,
Re: LA heads on a magnum block? [Re: 6pakdakota] #2550271
09/15/18 12:27 PM
09/15/18 12:27 PM
W
Wedgeman Offline
Wedgeman  Offline
W
SO you removed .008....you are .022 down compared to LA's....
