Who sells the correct shaped upper and lower radiator hoses #2548204
09/10/18 01:13 AM
09/10/18 01:13 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Who sells the correct shaped upper and lower radiator hoses for the '71 340 Abody? I needed one quickly and went to the local supply-house and it's not correctly bent. Thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: Who sells the correct shaped upper and lower radiator hoses [Re: PAULS_340] #2548226
09/10/18 02:02 AM
09/10/18 02:02 AM
AndyF Offline
AndyF  Offline
I've had mixed success with hoses. If you have the correct part number then your chances of getting the correct shape improve. On my last project I ended up buying 3 different sets of hoses and used the ones that fit the best. They were all sold as replacement parts but they varied quite a bit from each other.
Re: Who sells the correct shaped upper and lower radiator hoses [Re: AndyF] #2548252
09/10/18 06:15 AM
09/10/18 06:15 AM
IN
ahy Offline
ahy  Offline
IN
I had good luck with NAPA last time.
Re: Who sells the correct shaped upper and lower radiator hoses [Re: PAULS_340] #2548267
09/10/18 09:30 AM
09/10/18 09:30 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I don't know if this will help but if you go to rockauto.com and look up the hose you need you will see pictures of the hoses available from various manufacturers. You can also get the part numbers. I think the NAPA website also includes pictures of the parts. I had problems finding the correct molded hose for my Dodge truck. The ones the parts stores had were not correct. Then I figured out my truck had a radiator with the top hose fitting in the wrong location.
Re: Who sells the correct shaped upper and lower radiator hoses [Re: PAULS_340] #2548489
09/10/18 06:33 PM
09/10/18 06:33 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
just got an upper and lower for a 76 duster from Rock auto, the bends matched my 25 yr old hoses that were on it
