'67 440 lifters? #2547754
09/08/18 11:38 PM
09/08/18 11:38 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Why are 1967 440 lifters different than other years? What are the differences?
Re: '67 440 lifters? [Re: markrr] #2547760
09/08/18 11:54 PM
09/08/18 11:54 PM
A727Tflite Offline
A727Tflite  Offline
Early pushrod cups in the lifters were very small and the pushrod end for thenlifter was a pencil point design where later they went to a larger ball/radius.
Not sure what year we went to ball but around that time frame if I recall correctly.
Re: '67 440 lifters? [Re: markrr] #2547795
09/09/18 01:33 AM
09/09/18 01:33 AM
Mopar specified 1/4 pushrod cups in all their V8 lifters up to 1967, 5/16 after that shruggy scope
Re: '67 440 lifters? [Re: markrr] #2547879
09/09/18 12:08 PM
09/09/18 12:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As long as the lifters and pushrods are for the same year, it’s not a problem.
67 and earlier lifters need 67 and earlier pushrods.
68 and later lifters need 68 and later pushrods.
Re: '67 440 lifters? [Re: markrr] #2548189
09/10/18 12:37 AM
09/10/18 12:37 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Thanks for the answers.
Can anyone tell where would be the best place to buy a set of '67 1/4" pushrods? Are there any brands that are better or worse than others?
Re: '67 440 lifters? [Re: markrr] #2548208
09/10/18 01:26 AM
09/10/18 01:26 AM
Do you want stock size and type replacement pushrods or better after market ones? work
I may have enough of the originals ones for complete set work
If you want better than stock I am a dealer for Manton and they will make what ever you want that will be a lot stronger and stiffer than the stock OEM ones are.
PM me on here if you want help on this up
Re: '67 440 lifters? [Re: Cab_Burge] #2548383
09/10/18 02:04 PM
09/10/18 02:04 PM
dogdays Offline
dogdays  Offline
It isn't the pushrod that's 1/4", just the tip. You want the largest diameter pushrod that'll fit in your engine.
Actually if you're buying new pushrods I'd think seriously about changing to the later style lifters and pushrods.
R.
Re: '67 440 lifters? [Re: dogdays] #2548389
09/10/18 02:16 PM
09/10/18 02:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
R.
Totally agree.
Re: '67 440 lifters? [Re: markrr] #2548460
09/10/18 05:06 PM
09/10/18 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Custom pushrods can be made with a wide variety of ball sizes.
Re: '67 440 lifters? [Re: markrr] #2548491
09/10/18 06:42 PM
09/10/18 06:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you’re installing a new cam and lifters, that’s what I’d do.
Re: '67 440 lifters? [Re: Cab_Burge] #2551903
09/19/18 12:49 PM
09/19/18 12:49 PM
Cab is that the same on solid lifters?
