Opinions on this trunk pan, replaced or not replaced? #2547409
09/07/18 11:02 PM
09/07/18 11:02 PM
PA
Moparpete Offline OP
PA
not sure if I am seeing a seam or not down the middle and should those round indentations be cut and have the black body plugs, this is in a 70 satellite
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547414
09/07/18 11:17 PM
09/07/18 11:17 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Are you questioning if it's the original trunk pan? If that is the question, I'd say it's not; you can see plug welds on the far right and left hand sides of your picture, not spot welds.
Can you clarify your question a little further? I mean, even if there was a gapping foot long rust whole down the center, it's your car and your decision to replace it or not.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547420
09/07/18 11:21 PM
09/07/18 11:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I can tell by the spot welds along the edges that the center is completely not original to the car, if that is what you want to know. The center may have been replaced or it may have been patched, but it appears to be a weld seam near the spare tire and on both sides of the upside down picture. Gene
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547421
09/07/18 11:25 PM
09/07/18 11:25 PM
PA
PA
not my car,a friend is looking at it and the seller is not sure if the pan was replaced or not.its not a local car to him so all he has to go on is pictures, he said the same thing that it looks like it was replaced at some point...thank you for the opinions
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547433
09/08/18 12:16 AM
09/08/18 12:16 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Junk work that is.
Sheldon
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547434
09/08/18 12:24 AM
09/08/18 12:24 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Re-read your title, yes, it has been replaced. As others have pointed out, it was not replaced very well either. It works though; depending on what your friend plans on doing with the car, it does not have to be replaced any time soon. I would definitely subtract money for that job though if the asking price does not already reflect that issue.
If you went through all that work, at least you could have dressed the welds a little better.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: RUNCHARGER] #2547437
09/08/18 12:46 AM
09/08/18 12:46 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By RUNCHARGER
Junk work that is.
Yes it's been replaced by a total hack
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547463
09/08/18 02:13 AM
09/08/18 02:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Not every car has to be 100% factory correct to be a decent, fun ride.
It is fine to have high standards but unless the car is used for concourse judged events and trailered everywhere, why the hostility?
Yeah, the work looks ugly but is the floor strong? Can it hold weight? Remember people...Before idiots started paying stupid money for these things, they were $800 cars that we used to drive on gravel roads, in snow, rain, extreme heat, etc.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547466
09/08/18 02:26 AM
09/08/18 02:26 AM
P
Porter67 Offline
Porter67  Offline
P
I think you question is a bit vague.
My thoughts are is how much does one want to spend on a 70 sat?
Does he plan to keep it?
Make it into a show car or driver?
What does the rest of the car look like, hard to imagine if it had this done that the rest is quality work.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Porter67] #2547533
09/08/18 11:28 AM
09/08/18 11:28 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
I used half pans on a couple of cars. I did better clean up of the welds and seem and they came out great. I agree that you should look at the rest of the workmanship. If you were to replace them I think you have to use half pans again, since that is needed to fit through the trunk opening.
If the car is good for the price, buy a trunk mat and enjoy it
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547535
09/08/18 11:39 AM
09/08/18 11:39 AM
PA
PA
here is the car https://www.forbbodiesonly.com/moparforum/threads/1970-plymouth-satellite.158157/ it a nice looking car not sure about 26k nice my friend is passing in the car
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2547549
09/08/18 12:05 PM
09/08/18 12:05 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
That's a nice looking car; love the color.
If it's not far, it could be worth a drive to check it out at least.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: parksr5] #2547587
09/08/18 01:29 PM
09/08/18 01:29 PM
RUNCHARGER Offline
RUNCHARGER  Offline
See, that's the deal. If you want to do a low quality repair and drive it that is fine. Nothing wrong with that.
If you want $25k for your 318 Satellite, well then that low quality repair doesn't make it.
Sheldon
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Kern Dog] #2547824
09/09/18 09:28 AM
09/09/18 09:28 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
iagree
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Plum440] #2548107
09/09/18 09:21 PM
09/09/18 09:21 PM
Minn
SportF Offline
SportF  Offline
Minn
Above sounds good to me as well.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2548119
09/09/18 09:43 PM
09/09/18 09:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good for him.
I hope everyone looking at that car comes to the same conclusion.
Car looks nice otherwise, but where else did the builder cut corners?
I would have to think hard about parting with 26 hunert for something with that quality werk...
I have mechanical Aptitude.
I can screw up anything.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2548177
09/10/18 12:08 AM
09/10/18 12:08 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This is a Sport Satellite with buckets and console, they are a way better looking car than a plain satellite. Car needs to be seen in person, it looks nice in the photos. Small block is a minor problem.
Re: Opinions on this trunk pan, replaced or not replaced? [Re: Moparpete] #2548233
09/10/18 02:17 AM
09/10/18 02:17 AM
P
Porter67 Offline
Porter67  Offline
P
FABO says it sold for 26.5 not sure us or ?
Kinda hard to follow there banter in the link.
Car looked like a nice color combo in the pics.
