Transmission Cooler Lines #2547279
09/07/18 05:44 PM
09/07/18 05:44 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
1989 Dakota 3.9 auto. My radiator sprung a leak around the filler neck so I'm changing it out this weekend. The trans lines currently run to the bottom of the rad. I've been told to just loop the 2 lines into each other and don't put them back in the rad. Thoughts? And BTW, the rad does not come with fittings for these lines. Can I reuse the current ones if I go that route or buy new ones? What size are they?
Grandma always said I had "hands of gold"!
Re: Transmission Cooler Lines [Re: CHRGR69] #2547303
09/07/18 06:38 PM
09/07/18 06:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Certain people prove they should not be listened to. Whomever told you to just loop it is that person. You should be able to reuse the fittings.
Don't be the exception.
Re: Transmission Cooler Lines [Re: Supercuda] #2547311
09/07/18 06:59 PM
09/07/18 06:59 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Re: Transmission Cooler Lines [Re: CHRGR69] #2547332
09/07/18 07:37 PM
09/07/18 07:37 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
It's not like your cab heater, in which if you don't care about heat you bypass it. Not only do you want it, I think an additional external cooler on trucks is a very good idea.
Facts are stubborn things.
Re: Transmission Cooler Lines [Re: CHRGR69] #2547398
09/07/18 10:26 PM
09/07/18 10:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You can loop the trans line together if you only plan on driving it up and down the driveway. More then that I would add an aftermarket trans cooler, the biggest one you can find if your pulling a trailer, or the 2nd biggest if your only driving around. Don't waste your money on the small ones. Gene
Re: Transmission Cooler Lines [Re: CHRGR69] #2547401
09/07/18 10:32 PM
09/07/18 10:32 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'm thinking about adding an external filter too. Prolong the life of trans, along with the external auxillary cooler
Re: Transmission Cooler Lines [Re: poorboy] #2547402
09/07/18 10:33 PM
09/07/18 10:33 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
B&M Super Cooler is a really nice piece.
Re: Transmission Cooler Lines [Re: CHRGR69] #2547557
09/08/18 12:39 PM
09/08/18 12:39 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
As I dig into it, there is an existing cooler in between the rad and condenser. Never had an issue before, so I will just continue to use this one. Thanks
