Re: LA heads on a magnum block?
[Re: 6pakdakota]
#2547055
09/07/18 03:30 AM
09/07/18 03:30 AM
RapidRobert
Lucky for you you have an early mag block with LA oiling.
[Re: 6pakdakota]
#2547471
09/08/18 02:53 AM
09/08/18 02:53 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
blow air thru the hole on block deck to ensure it is fully drilled to cam bearing...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 6pakdakota]
#2550204
09/15/18 07:15 AM
09/15/18 07:15 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My Magnum block had to be cut to 9.577 to square it up,,,,,,,,
