Page 3 of 4 1 2 3 4
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545706
09/04/18 04:03 PM
09/04/18 04:03 PM
Washington
madscientist Offline
Washington
Originally Posted By Raffaplymouth60
Originally Posted By an8sec70cuda
Front looks too loose to me.
I can not see the 8s !!! ... incredible .. engine is too fast for the frame ... Tires is 29.5x11.50x15 .. tonight i will check the front shock calvert 90-10 if work properly
You need a double adjustable shock in the front, not that 90/10 thing.
You have no real way to control the front suspension.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545733
09/04/18 05:11 PM
09/04/18 05:11 PM
Texas
RustyM Offline
RustyM  Offline
Texas
opinion:Its not the hit thats the problem, its chassis control, she tries to hook hard at the hit it seems.
Do you have travel limiters up front?
Shock control in front looks to be toast/nada.
In my minds eye the reason shock adjustment on rebound isn't making any difference is due really poor front suspension control and, perhaps too much bottle too soon but, wont know that until front end is tightened up.
If you just have90/10 front shocks- are they adjustable at all- can you go to 70/30 and at least lengthen up the bump stops?
I would tighten up rebound on rear shocks as far as they would go and try to tighten up the front.
Man i wish you could find a set of scales.
It also appears you "might" still need a little more air pressure.
We have found here that tires actually need a bit more pressure than we used to think.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545766
09/04/18 06:42 PM
09/04/18 06:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would try 6 flats of negative preload. big motors hit the cal tracks so hard they quickly rebound and lose traction maybe 12 flats negative.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545952
09/05/18 01:10 AM
09/05/18 01:10 AM
How old are the rear tires and how many runs on hem?
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546206
09/05/18 03:11 PM
09/05/18 03:11 PM
an8sec70cuda Offline
If you have Calvert's 90/10 front shocks, take them off and sell them and buy a decent DA shock. The Calvert 90/10s are WAYYY too loose. Any 90/10 is wrong for your car anyway.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: madscientist] #2546325
09/05/18 06:47 PM
09/05/18 06:47 PM
Italy
Raffaplymouth60 Offline OP
Italy
oook ... im working for buy double adj shock !
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: an8sec70cuda] #2546326
09/05/18 06:49 PM
09/05/18 06:49 PM
Italy
Italy
yes i have 90/10 Calvert..... why not work on my car ?????
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Cab_Burge] #2546328
09/05/18 06:50 PM
09/05/18 06:50 PM
Italy
Italy
29.5 11.50 15 MT with around 15 pass
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Dodgem] #2546329
09/05/18 06:53 PM
09/05/18 06:53 PM
Italy
Italy
now on the rear... qa1 double adjust all closed -6 compression -6 return
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: RustyM] #2546332
09/05/18 06:57 PM
09/05/18 06:57 PM
Italy
Italy
very good info ...i Will let you know.. if I can find the balance ...which benefits with 70/30 instead 90/ 10 ??
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546335
09/05/18 07:06 PM
09/05/18 07:06 PM
They are too loose. Lets the front rise too fast unloading the rear.
I tried the Calvert 90/10s on my car a long time ago and it refused to hook w/ them...that was running mid 9s on motor. Put stiffer shocks back on and it went back to working good. Slowing that rate of front separation does a lot.
The Viking double adjustable shocks I have now are much better.
CHIP
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546350
09/05/18 07:28 PM
09/05/18 07:28 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Bars need to be in the bottom hole, PERIOD!
It hits the tire hard then unloads
You need push not bang
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546363
09/05/18 08:13 PM
09/05/18 08:13 PM
How old are they and do they sit outside in the sun light when not in use?
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546395
09/05/18 09:17 PM
09/05/18 09:17 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Cab is getting at something here, and I agree. The sidewalls are most likely killed from the combination of power/ weight, and running such low air pressure.
Put me in with the guys that suggest front shocks also.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Cab_Burge] #2546749
09/06/18 03:59 PM
09/06/18 03:59 PM
Italy
Italy
No sun ... 1 year age
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546751
09/06/18 04:02 PM
09/06/18 04:02 PM
Italy
Italy
Finally
Little bit less shot in 1 step 150 hp wide time from 1 step to 2 step before 2 sec.. now 3 sec ?
caltracs at bottom hole
new front shock Viking or AFCO
Torsion bars ??? is possible have drag racing torsion bars ?? mine is original from the car
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546755
09/06/18 04:10 PM
09/06/18 04:10 PM
What engine was in your car originally? Don't get the drag race torsion bars...they'll make it worse. Like a loose shock, a loose torsion bar is not what you want.
The Cal-Tracs in the bottom hole will soften the hit. I still think you need more air pressure. My car responded well to adding air pressure from 12 up to 14-15 psi.
CHIP
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546773
09/06/18 04:42 PM
09/06/18 04:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Add weight to the trunk. If 70# on front hurt then add 100# to rear.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2546867
09/06/18 07:55 PM
09/06/18 07:55 PM
Texas
RustyM Offline
RustyM  Offline
Texas
I agree with an8sec70cuda here: Front shocks and front suspension is too loose/too fast in both planes.
Car tries to carry the front and certainly has the power, she seems to grip at the hit but- the front "bounces up, then drops down".
When coming down, it comes down too fast and, to far, when the car pivots forward on the front- rear is unloaded.
Granted it started to slip/spin at apex of front coming up.
Think of a piston at the top of the stroke- for a microsecond- it stops.
Same with the front end travel, it stops moving up and immediately starts down and that movement changes weight transfer.
We are working on one here with the same issues.
adjustable bump stops or travel limiters can help some but you really, really need adjustible shocks and- a set of dang scales.
If i could i would ship you a set to set up with.
Why?
lets say you car is on scales and this is what they say:
Lf- 946 RF- 796
LR-756 RR-848
car is left front, right rear heavy- really not good.
A QUARTER TO HALF TURN ON A TORSION BAR will pretty well level out the weight bias on the car.
the point is- it only takes a tiny bit of torsion bar misadjustment to have car unhappy.
Hope this helps.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: RustyM] #2546876
09/06/18 08:11 PM
09/06/18 08:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW I've been a 1.33 60 ft. with Rancho 90-10 fronts and 5-ways out back but every car is different up to a point........
Page 3 of 4 1 2 3 4
