71 Barracuda Rear Tailight panel color? #2546579
09/06/18 09:59 AM
09/06/18 09:59 AM
OK
Boes71conv Offline OP
OK
I have a 1971 Barracuda Convertible I'm restoring and was wondering how to tell if the rear taillight panel was the original body color or flat black. I have some pictures from the previous owner that goes back to 1973 showing it flat black. Could this be correct?
Thanks,
Re: 71 Barracuda Rear Tailight panel color? [Re: Boes71conv] #2546606
09/06/18 11:12 AM
09/06/18 11:12 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Do you have the rear M88 stainless trim around the rear panel perimeter?....if not, then No black out should be present
It's a Barracuda?, not a Gran Coupe correct?
Re: 71 Barracuda Rear Tailight panel color? [Re: DAYCLONA] #2546715
09/06/18 02:58 PM
09/06/18 02:58 PM
OK
OK
There is no stainless and it is a Barracuda.
Thanks,
Re: 71 Barracuda Rear Tailight panel color? [Re: Boes71conv] #2546824
09/06/18 06:25 PM
09/06/18 06:25 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
My 71 barracuda vert did not have the stainless trim at the rear panel and was painted body color. 2nd owner.
Re: 71 Barracuda Rear Tailight panel color? [Re: Boes71conv] #2546901
09/06/18 08:57 PM
09/06/18 08:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Your fender tag will be coded M88 if it was black and had trim.
Back in the 80s I parted out a 70 Barracuda with A22 rubber bumpers and M88 rear panel trim and flat black
