drum brake question #254604
03/15/09 05:28 PM
03/15/09 05:28 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
i was changing out my third member and when I was putting my brakes back I noticed the push rod was extended alittle too much and I took the boot off the cylinder and its extended alittle over a 1/4 inch and the brake shoe does'nt seat right...so my question is.... is the cylinder shot or can I bleed it down??
Re: drum brake question [Re: ngpSatellite] #254605
03/15/09 05:48 PM
03/15/09 05:48 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
i was changing out my third member and when I was putting my brakes back I noticed the push rod was extended alittle too much and I took the boot of the cylinder and its extended alittle over a 1/4 inch and the brake shoe does'nt seat right...so my question is.... is the cylinder shot or can I bleed it down??
Please state the problem again.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: drum brake question [Re: HealthServices] #254606
03/15/09 05:49 PM
03/15/09 05:49 PM
So Cal
So Cal
piston pop out? If so you can just push it back in if you don't fold the cup over. Then just re bleed the brakes
Re: drum brake question [Re: HealthServices] #254607
03/15/09 05:53 PM
03/15/09 05:53 PM
own private Idaho
N
N
own private Idaho
yes the piston on one side of my cylinder is almost a half inch out
Re: drum brake question [Re: ngpSatellite] #254608
03/15/09 05:56 PM
03/15/09 05:56 PM
So Cal
So Cal
Crack the bleeder loose.
Push piston in. Careful - Push both pistons in at the same time.
Tighten screw.
assemble brakes.
Bleed brakes
Re: drum brake question [Re: HealthServices] #254609
03/15/09 05:59 PM
03/15/09 05:59 PM
own private Idaho
N
N
own private Idaho
cool thanks Allen...
Re: drum brake question [Re: HealthServices] #254610
03/15/09 06:07 PM
03/15/09 06:07 PM
own private Idaho
N
N
own private Idaho
It worked!!!..... Thanks again ... this Moparts site is priceless!!!!
Re: drum brake question [Re: ngpSatellite] #254611
03/15/09 08:51 PM
03/15/09 08:51 PM
So Cal
So Cal
