Page 2 of 3 1 2 3
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: LYNCHROAD69.5] #254523
03/18/09 08:38 AM
03/18/09 08:38 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If you do have a bad voltage regulator, I think FBO Ignitions had the converted stock looking electronic regulators that look like the old points ones.
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: jbc426] #254524
03/18/09 08:10 PM
03/18/09 08:10 PM
Anonymous OP
Anonymous OP
just an update to the problem, the J2 drk blue wire with tracer from ignition 1 that goes from the bulkhead in the engine compartment to the voltage regulator had a bad connection.
my good friend VCODE Bob came to my rescue with his little batman kit and saved the day. he has more knowledge than you want to know and a terrific guy.
he'll chime in and give the details but for now its fixed and running perfectly.
Re: A12 Idle solenoid TROUBLESHOOTING problem #254525
03/18/09 08:43 PM
03/18/09 08:43 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Hey Chris (mr lucky)
This one gave me a run for the money
It was the J2 DBL/W wire at the firewall bulkhead.We found a bad connection.The wire was not making good contact where the wire is crimped to the male blade terminal inside the 8 wire connector.The J2 goes from the Ignition switch to the bulkhead then feeds the Regulator which in turn feeds the resistor,coil,alt,and solenoid.
Hope this helps someone
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: VCODE] #254526
03/18/09 09:07 PM
03/18/09 09:07 PM
SE Pa.
LimeliteAero Offline
SE Pa.
GOOD NEWS!
Now take off those silly wheel disks.
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: VCODE] #254527
03/18/09 10:05 PM
03/18/09 10:05 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
So was it caused by the shorting of the solenoid wire, a bad connection or a combination of both?
MikeR
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: A12] #254528
03/18/09 10:14 PM
03/18/09 10:14 PM
Anonymous OP
Anonymous OP
MikeR
my feeling is that the wire got hot and did something to the connector.i think the wire connector fitment might have been iffy to begin with and this just added to the problem.its a repro a12 wiring engine harness.
Re: A12 Idle solenoid TROUBLESHOOTING problem #254529
03/18/09 10:36 PM
03/18/09 10:36 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Do you know who made the harness?
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: LimeliteAero] #254530
03/19/09 04:50 AM
03/19/09 04:50 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
GOOD NEWS!
I was thinking the more I see them the more I like them.
I can't afford this. mark
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: a12superbee] #254531
03/19/09 07:18 AM
03/19/09 07:18 AM
Anonymous OP
Anonymous OP
GOOD NEWS!
its funny you said that as i was looking at the car yesterday and they are reall growing on me.
Even VCODE Bob thought they looked pretty cool.
only 1 company makes the A12 engine wiring harness.
Re: A12 Idle solenoid TROUBLESHOOTING problem #254532
03/19/09 10:24 AM
03/19/09 10:24 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: A12 Idle solenoid TROUBLESHOOTING problem #254533
03/19/09 11:43 AM
03/19/09 11:43 AM
Snoopy Offline
Snoopy  Offline
There are at least two companies that make the engine bay harnesses.
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: Snoopy] #254534
03/19/09 03:48 PM
03/19/09 03:48 PM
Anonymous OP
Anonymous OP
thats true but only bill and rose evans sells the A12 engine wire harness.
Re: A12 Idle solenoid TROUBLESHOOTING problem #254535
03/19/09 03:55 PM
03/19/09 03:55 PM
Snoopy Offline
Snoopy  Offline
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: Snoopy] #254536
03/19/09 03:58 PM
03/19/09 03:58 PM
Snoopy Offline
Snoopy  Offline
I have read numerous posts on Moparts over the years concerning loose connections on some of the wiring harnesses built by Evans, that's why I asked the question.
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: Snoopy] #254537
03/19/09 04:03 PM
03/19/09 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , same here , I have an Evans harness and some of the connections pulled off . Plus the Evans harness does not duplicate the factory A12 harness .
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: A12] #254538
03/19/09 04:04 PM
03/19/09 04:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is this the connection at the ballast resistor and is this a key activated 12 v power source?
Mike, the connection on the ballast resistor is for the COIL , the idle solenoid is connected to the voltage regulator .
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: JohnRR] #254539
03/19/09 04:13 PM
03/19/09 04:13 PM
Snoopy Offline
Snoopy  Offline
John,
Doesn't the idle solenoid plug into the special connector on the coil wire that plugs into the regulator?
Re: A12 Idle solenoid TROUBLESHOOTING problem #254540
03/19/09 04:26 PM
03/19/09 04:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sorry, But Frank Badalson/Roger Gibson also makes it and I've never heard any complaints about theres
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: gtx6970] #254541
03/19/09 04:35 PM
03/19/09 04:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It's the only correct one to my knowledge.
Re: A12 Idle solenoid TROUBLESHOOTING problem [Re: HPMike] #254542
03/19/09 04:48 PM
03/19/09 04:48 PM
Snoopy Offline
Snoopy  Offline
I think you will find that Year One supplies the harnesses to Frank Badalson/Roger Gibson and they are made by M&H.
Having said that, it looks like he has added the label and seems to have a lower list price than Year One.
69EH This is the only correct 69 ½ engine harness available. Correct modifications unique
to the 1969 ½ 440-6 cars only. Furnished with correct part number tag $105.00
69EHS ………………….with solenoid wire……………………..$130.00
69EHSB ……….with ballast resistor to coil wire…………………….$140.00
Page 2 of 3 1 2 3
