1974 Plymouth Satellite Tie Rod Question
#2545096
09/03/18 02:13 PM
09/03/18 02:13 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Real simple
From outer tie-rod to inner tie rod center lines, are dimensions of this measurement supposed to be the some from side to side?
Right now, the Satellite had 14 inces CL to Cl dimension on one side and 12 inches on the other.
I know they should match, looking for confirmation. This car is eating tires to the tune of one a month, something is very wrong up front with only maybe 1/4 toe-in being measure right now. But, this difference should do nothing but un-center the steering wheel, right?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: 1974 Plymouth Satellite Tie Rod Question
[Re: 70Coronet500Vert]
#2545190
09/03/18 04:50 PM
09/03/18 04:50 PM
RapidRobert
I would center the steering wheel (halfway between lock to lock) then adj the tires straight ahead then a 1/16"-1/8" of toe in (iirc), moveing each tire "in" a skosh to get that "total". Not sure if caster/camber gets adjusted before or after toe in but here is a BTT for ya.
[Re: 71birdJ68]
#2545454
09/04/18 12:32 AM
09/04/18 12:32 AM
RapidRobert
^^^ agreed, I missed that (obvious), that something is way out of whack.
#2545532
09/04/18 10:11 AM
09/04/18 10:11 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Chances are it turns tighter in one direction than the other. Seen this many a time. Just center the s/wheel and then center the tie rod links. They should pretty even. Then adjust for toe in. The s/wheel and column coupler are indexed and can only go on one way.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
