1974 Plymouth Satellite Tie Rod Question #2545096
09/03/18 02:13 PM
09/03/18 02:13 PM
St Charles MO
70Coronet500Vert Offline OP
St Charles MO
Real simple
From outer tie-rod to inner tie rod center lines, are dimensions of this measurement supposed to be the some from side to side?
Right now, the Satellite had 14 inces CL to Cl dimension on one side and 12 inches on the other.
I know they should match, looking for confirmation. This car is eating tires to the tune of one a month, something is very wrong up front with only maybe 1/4 toe-in being measure right now. But, this difference should do nothing but un-center the steering wheel, right?
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545190
09/03/18 04:50 PM
09/03/18 04:50 PM
I would center the steering wheel (halfway between lock to lock) then adj the tires straight ahead then a 1/16"-1/8" of toe in (iirc), moveing each tire "in" a skosh to get that "total". Not sure if caster/camber gets adjusted before or after toe in but here is a BTT for ya.
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545197
09/03/18 04:59 PM
09/03/18 04:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I am not sure if the toe in will cause as much wear as you are getting but I have always thought it should be an 1/8". What type of wear pattern are you seeing?
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545346
09/03/18 09:18 PM
09/03/18 09:18 PM
St Charles MO
St Charles MO
thx
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545441
09/03/18 11:52 PM
09/03/18 11:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
With it that out of whack and eating tires, I think I would go to square one by the book and redo everything. Disconnect the pitman arm and center the steering box shaft, then the column shaft coupler, then the steering wheel. That way you will know everything is right from the box back. Then center the tires with the tie rods.
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 71birdJ68] #2545454
09/04/18 12:32 AM
09/04/18 12:32 AM
^^^ agreed, I missed that (obvious), that something is way out of whack.
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545522
09/04/18 09:25 AM
09/04/18 09:25 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I'd start with removing an inch from 1 assembly and adding an inch to the other.
Re: 1974 Plymouth Satellite Tie Rod Question [Re: 70Coronet500Vert] #2545532
09/04/18 10:11 AM
09/04/18 10:11 AM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Chances are it turns tighter in one direction than the other. Seen this many a time.
Just center the s/wheel and then center the tie rod links. They should pretty even. Then adjust for toe in.
The s/wheel and column coupler are indexed and can only go on one way.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
