piston to valve clearance Q #2545169
09/03/18 04:09 PM
09/03/18 04:09 PM
RapidRobert Offline OP
EQ mag headed 360 with hyd #718041-09 .521/.512 Howards cam. will be raced only. If my preload on mockup is .030" and I with clay or dial indicator check P/V clearance with an adjustable solid lifter like the one Hughes sells/rents (1) should I (A) lock the cup at .030" down from the snap ring & check it or (B) lock it just under the snap ring? (2) should I use the pushrod that gave me .030" preload? I may as need get different pushrods. (3) ~6200 max RPM and I have 2 sets of springs 142/308 and 142/312 lbs to choose from (closed/open), which do you suggest (they are close). My shop wants .080/.100 P/V clearance but I am severely stuck on the procedure. Thank you for your time.
Re: piston to valve clearance Q [Re: RapidRobert] #2545185
09/03/18 04:40 PM
09/03/18 04:40 PM
montreal, quebec,canada
7e5dartsport Offline
adjustable solid lifter??? because a hydraulic lifter would bleed during the procedure, i would use a solid lifter to check the p/v clearance. with an adjustable pushrod or an adjustable rocker. set that valve at zero lash then you can take measurements of your piston to valve clearance. that would be with clay. otherwise, you can use a checking spring and measure at different positions of the crank directly by pushing down on the retainer and measuring from the retainer with a dial indicator. this would be more accurate than clay and it is how i do it.
fully legal sounds the same as full illegal...
Re: piston to valve clearance Q [Re: RapidRobert] #2545198
09/03/18 05:00 PM
09/03/18 05:00 PM
with a checking spring you could use a hydraulic lifter. to directly answer your question, i doubt that lifter preload has a big effect on p/v clearance. in doubt, check it at both zero lash and then with .030 preload.
Re: piston to valve clearance Q [Re: 7e5dartsport] #2545211
09/03/18 05:09 PM
09/03/18 05:09 PM
My bad, an adjustable HYD lifter like Hughes has (that can be locked solid at different cup heights (to match the preload). OK, if I have enough clearance with it checked with the cup locked just under the snap ring will I be OK? I would think I would be OK unless things actually "seperated" floated? (if that is possible) but for sure I have been sweating bullets over this! (& the geometry issue).
Re: piston to valve clearance Q [Re: RapidRobert] #2545293
09/03/18 06:55 PM
09/03/18 06:55 PM
I would check it with checking springs and a solid lifter first scope I have ran as little as .030(accidently blush) on the intake valve to piston, you have to check all eight of them also and as little as .050 on the exhausts. I had mock that engine up and every thing was good at the beginning of the season, half way through that year I removed the heads and had them cut down from 86.0 CC to the legal 81.5 CC NHRA spec. that stupid car didn't run any different with that change whiney
I found the close valves to pistons clearances when I tore that motor down the next time shock Ended up that I had some longer stock rods and some shorter ones blush I was lucky that I didn't break any parts on that deal boogie
Check, check and check again, especially on race motors up scope
Re: piston to valve clearance Q [Re: Cab_Burge] #2545381
09/03/18 10:31 PM
09/03/18 10:31 PM
Cab I have some solids/adjustable pushrod checkers/light springs but would the slightly different "angle" give me a false reading or is that a moot point?
Re: piston to valve clearance Q [Re: RapidRobert] #2545459
09/04/18 12:53 AM
09/04/18 12:53 AM
I think the angle change will either increase or decrease the V to P clearances by a very small amount(.001 to ,maybe .003), probably not enough to worry about work
Re: piston to valve clearance Q [Re: Cab_Burge] #2545479
09/04/18 02:10 AM
09/04/18 02:10 AM
that's good to hear! thanks Cab. I will get after it
