I would check it with checking springs and a solid lifter first
I have ran as little as .030(accidently
) on the intake valve to piston, you have to check all eight of them also and as little as .050 on the exhausts. I had mock that engine up and every thing was good at the beginning of the season, half way through that year I removed the heads and had them cut down from 86.0 CC to the legal 81.5 CC NHRA spec. that stupid car didn't run any different with that change
I found the close valves to pistons clearances when I tore that motor down the next time
Ended up that I had some longer stock rods and some shorter ones
I was lucky that I didn't break any parts on that deal
Check, check and check again, especially on race motors
