Page 1 of 3 1 2 3
World block ? #2544888
09/03/18 01:26 AM
09/03/18 01:26 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
I broke a stock block now am looking at aftermarket .
I have a unused World block I can buy . Here in Oz !
It is a 4.310 bore still in crate .
What if any issues should I be aware of ?
I will use my current 4.25 crank , rods etc and go to 4.350 bore
thanks in advance
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: World block ? [Re: tex013] #2544889
09/03/18 01:30 AM
09/03/18 01:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
Is it iron or aluminum? Can you have it sonic tested before boring it? If so, do that for your own knowledge, future use and peace of mind up
Re: World block ? [Re: tex013] #2544918
09/03/18 02:37 AM
09/03/18 02:37 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Cab ,
is an iron block - my preference
Good idea
Tex
New best MPH 130.32
Re: World block ? [Re: tex013] #2544920
09/03/18 02:40 AM
09/03/18 02:40 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Don’t bore it any bigger than you have to. Those things are kinda rare.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: World block ? [Re: tex013] #2544936
09/03/18 04:10 AM
09/03/18 04:10 AM
Originally Posted By tex013
Cab ,
Good idea
Tex
iagree bow grin
Re: World block ? [Re: pittsburghracer] #2544941
09/03/18 04:45 AM
09/03/18 04:45 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
yes they are .
at 4.350 , current piston , leaves a lot .
Not sure there is a standard bore piston to suit 4.25 stroke and 7.1 rod . Would be custom ? Cost is then through the roof .
Its a 15 hr drive interstate , have to rent a van realcrazy
But if is as described will be worth it
Tex
New best MPH 130.32
Re: World block ? [Re: tex013] #2545083
09/03/18 01:33 PM
09/03/18 01:33 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
440Source shows 2 different dished pistons and a flat top for your combo. They also say that this is the same as their 470 low deck piston. That might give you different avenues to check out your way. I have heard that Icon makes the pistons for 440Source, so they aren't a bad piece. Icon pistons are also available through Summit.
[image][/image]
Re: World block ? [Re: sgcuda] #2545111
09/03/18 02:30 PM
09/03/18 02:30 PM
iagree One of the tech guys at Icon told me that also several years back, I had called to see if they would make custom pistons, they wouldn't whiney
They gave me a part # for one of their pistons that I hadn't seen that worked out real well for that build up
Re: World block ? [Re: tex013] #2545114
09/03/18 02:32 PM
09/03/18 02:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Head deck holes drilled thru the head deck into the water jacket is the major one we got hit with.
The last cam bearing bore under sized is another.
Thrust face not machined to final width...
Re: World block ? [Re: tex013] #2545243
09/03/18 05:46 PM
09/03/18 05:46 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Quite simply, check EVERYTHING on those. Deck height, bolt holes,. bosses, alignment,. thickness', you name it., check it. They had a lot of junk they put out.Most of it serviceable AFTER everything was fixed, but just look at everything very closely.Since your on the land of Oz, its nice to even have a chance to get a new iron block, but beware.
RIP Monte Smith
Re: World block ? [Re: tex013] #2545315
09/03/18 07:33 PM
09/03/18 07:33 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok
thanks guys .
Dragula , I presume you just treated that like a chev ? and used bolt sealer .
Compwedge , I will have to give a good visual . And cross my fingers a little . Then send it off to machine shop .
Like everyone I am caught between a rock and a hard place .
A KB is just too much $ and I cannot justify it . This is spendy enough ! At least this is a new block I can hold - not a hand full of smoke and wishes .
I will email ICON to see if they do a stock piston
Tex
New best MPH 130.32
Re: World block ? [Re: tex013] #2545421
09/03/18 11:16 PM
09/03/18 11:16 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Pics
Tex
Resized_Screenshot_20180904-095200_Gallery_6667.jpegResized_20180904_095818_2588.jpegResized_20180904_095853_9438.jpeg
New best MPH 130.32
Re: World block ? [Re: tex013] #2545451
09/04/18 12:14 AM
09/04/18 12:14 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Even in the States those blocks are like hens teeth.
Re: World block ? [Re: tex013] #2545635
09/04/18 01:49 PM
09/04/18 01:49 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The earliest 3944 (+ others) wedge blocks have a ditch machined next to the motor mount ears (presumably for bolt head clearance). As a result early Wedge blocks can POTENTIALLY be thin in that area. (From water jacket to outside of block, right next to the stock motor mounts). Most of them are fine. Most. But, take a look.
If you have this early variant with the ditch, definitely don't be afraid to run it...Just use a motor plate whether on a dyno or in a car.
If you have a sonic tester with a flat probe (personally I just have an ebay cheapie, not the big baller lab $tuff), you may find the probe will fit into the ditch to give a better idea of thickness...It might be 3/8 thick which may seem good to go! Well, even if the material is sufficiently thick, the ditch machining was finished in a very "squared off" manner, and it is a stress riser.
Now...If you have the later version without the ditch (I'd have to go and check on the exact date we fixed it, but I believe it was 2008 to early 2009), that's a better block than the older one. However after seeing how much the side of the block distorts....I'd really recommend a motor plate for most apps.
Needless to say there is a old story or 14 surrounding this.
The Hemi never had this exact issue, as the mounts were completely chopped off.
Check the block for a machining date (stamped/etched in) and report back if possible.
Rich H.
Esse Quam Videri
Re: World block ? [Re: ZIPPY] #2545790
09/04/18 07:36 PM
09/04/18 07:36 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Zippy ,
I could always use the hemi style lower mounts ? If this was the case ? And just use schumaker conversion mounts . I really do not want a motor plate .
I am off to look/buy next week .
Tex
New best MPH 130.32
Re: World block ? [Re: tex013] #2545816
09/04/18 08:29 PM
09/04/18 08:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
There's a guy in Ohio who has been advertising a new World 4.50"-bore iron block for MONTHS on RacingJunk. At his $6500 listed price, I'm sure he's praying somebody buys it before the new KB blocks are readily available.
Re: World block ? [Re: tex013] #2545817
09/04/18 08:32 PM
09/04/18 08:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Unfortunately many early blocks also have what appears to me to be deliberate carving in that specific area for really no reason other than to make it impossible to use hemi style mounts.
You've been around, and I am sure your best judgement will be enough.
Thought it might help to put those small details out there since it's not really widely known stuff.
Good luck!
Rich H.
Esse Quam Videri
Re: World block ? [Re: tex013] #2545858
09/04/18 10:01 PM
09/04/18 10:01 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Zippy ,
thank you again , plus everyone else .
Your information/help is priceless .
Brad , I saw that block .
That's the price you pay if that's all there is . I do not want to risk a worse breakage result
Tex
New best MPH 130.32
Re: World block ? [Re: BradH] #2545932
09/05/18 12:05 AM
09/05/18 12:05 AM
AndyF Offline
AndyF  Offline
Wow that is a lot. I was planning to sell my race engine this year but I was going to ask roughly that number for my short block. The short block is a World cast iron block with a Callies crank and Oliver rods. If people are asking that for a bare block maybe I should up my number.
Re: World block ? [Re: AndyF] #2545941
09/05/18 12:28 AM
09/05/18 12:28 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Hey Andy
can I run a powermaster birdcage alternator with your 3/8" motor plate ?
Tex
New best MPH 130.32
Page 1 of 3 1 2 3
