Quite simply, check EVERYTHING on those. Deck height, bolt holes,. bosses, alignment,. thickness', you name it., check it. They had a lot of junk they put out.Most of it serviceable AFTER everything was fixed, but just look at everything very closely.Since your on the land of Oz, its nice to even have a chance to get a new iron block, but beware.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
