To much flow ? Not enough Velocity #2544175
09/01/18 11:12 AM
09/01/18 11:12 AM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Just like it says . Had the heads and intake max port well without making then water sprinklers and now the car comes out real lazy then picks up. I have tried new msd box, crank trigger, moved the timing around, this is the second converter, with a third on its way(ati but had it reworked) my 60ft is way way way off .. running 1.70 but had a high mph of 141. I don’t know where to go from here. Is the intake to big for my comb ? I’m at a loss right now and don’t want to think I spent all that money for nothing for the heads and intake. And help would be great. Thanks John
https://youtu.be/DD7VwgIT6go
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544180
09/01/18 11:33 AM
09/01/18 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What rpm are you leaving at.. you might need to
advance your cam to get back into your power
range.. have you checked everything from when
you pulled your heads.. sounds like something
is off with a 1.70 60ft.. a decent street car
does that good
wave
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544184
09/01/18 11:41 AM
09/01/18 11:41 AM
Deerfield, Ohio
Deerfield, Ohio
I agree, I have checked torn it apart and checked . I’m a foot brake racer . So hard idle .
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544266
09/01/18 02:11 PM
09/01/18 02:11 PM
Years ago when Bob Mazolini first switch his old SS/DA car to SS/BM modify car with a 411 C.I B1 motor in it, he had a 6000 RPM converter in the Powerglide for the first run, it was real lazy in the 60 fts. and ran 10.30 at 142+ MPH, he swapped the converter to a 7200 RPM for the next run and the car went 9.35 at 148.+ MPH with no other changes boogie work
That motor was 411 C.I. with a 4.500 bore and what ever stroke it needed to make 411 C.I.
My message is the motor needs to be ran in its power band work
IHTHs thumbs
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544289
09/01/18 03:15 PM
09/01/18 03:15 PM
Deerfield, Ohio
Deerfield, Ohio
Thanks cab, our ati was about 5,700 but was still to tight, so I sent it out for another 1,200 I hope that gets me closer ..
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544291
09/01/18 03:19 PM
09/01/18 03:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It will be faster but it looks like your going to need more launch rpm and carb work
Re: To much flow ? Not enough Velocity [Re: FastmOp] #2544304
09/01/18 04:00 PM
09/01/18 04:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agree, more volume doesn't necessarily guarantee more "power" till you do the needed changes to extract it just like a big cam, you need more gear, vert, higher shift points and MAYBE bigger carb etc.............. beer thumbs
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544313
09/01/18 04:22 PM
09/01/18 04:22 PM
Deerfield, Ohio
Deerfield, Ohio
I know I need carb work but it’s hard to do when the car isn’t running anywhere near what it should. I have a 4.30 in it now and I’m shifting at 7,500. I know a 56 or 89 would be better just not in the cards right now .
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544315
09/01/18 04:33 PM
09/01/18 04:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Try advancing your cam so it will lower the RPM
into a range your engine can deal with.. or
change to injection so you only move air..
but I doubt you want to change now
wave
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544339
09/01/18 06:04 PM
09/01/18 06:04 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I agree, advance it (if you have the intake valve P-to-V clearance) may show you something.
Boffin Emeritus
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544389
09/01/18 08:30 PM
09/01/18 08:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has pair of pretty big pair of -1s. Foot braking it's been 1.24 60ft. 727, 4.10,10.5Wx31,6000 rpm fall back on the shift. 1.70 60ft sounds like a stator/converter sprag issue.
Doug
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544474
09/02/18 12:30 AM
09/02/18 12:30 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Do you have a lean bog from the carb that is driving the bad 60ft???
Re: To much flow ? Not enough Velocity [Re: max_maniac] #2544518
09/02/18 08:50 AM
09/02/18 08:50 AM
Deerfield, Ohio
Deerfield, Ohio
No I’ve tried to raise the shooters and jet to no avail..
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544581
09/02/18 12:31 PM
09/02/18 12:31 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Something just isn't right. That is going to put your launch rpm just 600 rpm less than your shift point. I think a 5,700 rpm launch should be good enough for much better 60 ft. than 1.70's. You need to look in another direction. Are you sure you aren't leaving in second gear?
Re: To much flow ? Not enough Velocity [Re: sgcuda] #2544584
09/02/18 12:35 PM
09/02/18 12:35 PM
tboomer Online work
tboomer  Online Work
A long shot here...Is the shifter cable adjusted properly? work
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544594
09/02/18 12:57 PM
09/02/18 12:57 PM
Deerfield, Ohio
Deerfield, Ohio
Pretty sure I mean I have to shift 2 times ..
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544602
09/02/18 01:18 PM
09/02/18 01:18 PM
tboomer Online work
tboomer  Online Work
So if it is in neutral and you rev it a bit it doesn't creep a bit? Just trying to help here...
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544603
09/02/18 01:19 PM
09/02/18 01:19 PM
Deerfield, Ohio
Deerfield, Ohio
Yes it does
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544663
09/02/18 02:33 PM
09/02/18 02:33 PM
Deerfield, Ohio
Deerfield, Ohio
Could that really cause that big of an issue ?
Re: To much flow ? Not enough Velocity [Re: 70dusterjohn] #2544669
09/02/18 02:49 PM
09/02/18 02:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m going to say this about as simple as it gets. Get the car to 60 foot and the rest is all downhill from there. The first sixty foot is the hard part.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
