To much flow ? Not enough Velocity
#2544175
09/01/18 11:12 AM
09/01/18 11:12 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Just like it says . Had the heads and intake max port well without making then water sprinklers and now the car comes out real lazy then picks up. I have tried new msd box, crank trigger, moved the timing around, this is the second converter, with a third on its way(ati but had it reworked) my 60ft is way way way off .. running 1.70 but had a high mph of 141. I don’t know where to go from here. Is the intake to big for my comb ? I’m at a loss right now and don’t want to think I spent all that money for nothing for the heads and intake. And help would be great. Thanks John https://youtu.be/DD7VwgIT6go
Re: To much flow ? Not enough Velocity
[Re: 70dusterjohn]
#2544180
09/01/18 11:33 AM
09/01/18 11:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What rpm are you leaving at.. you might need to advance your cam to get back into your power range.. have you checked everything from when you pulled your heads.. sounds like something is off with a 1.70 60ft.. a decent street car does that good
[Re: 70dusterjohn]
#2544266
09/01/18 02:11 PM
09/01/18 02:11 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Years ago when Bob Mazolini first switch his old SS/DA car to SS/BM modify car with a 411 C.I B1 motor in it, he had a 6000 RPM converter in the Powerglide for the first run, it was real lazy in the 60 fts. and ran 10.30 at 142+ MPH, he swapped the converter to a 7200 RPM for the next run and the car went 9.35 at 148.+ MPH with no other changes That motor was 411 C.I. with a 4.500 bore and what ever stroke it needed to make 411 C.I. My message is the motor needs to be ran in its power band IHTHs
[Re: 70dusterjohn]
#2544315
09/01/18 04:33 PM
09/01/18 04:33 PM
MR_P_BODY
Try advancing your cam so it will lower the RPM into a range your engine can deal with.. or change to injection so you only move air.. but I doubt you want to change now
[Re: 70dusterjohn]
#2544339
09/01/18 06:04 PM
09/01/18 06:04 PM
Posts: 4,208 New York
polyspheric
New York
I agree, advance it (if you have the intake valve P-to-V clearance) may show you something.
Boffin Emeritus
[Re: 70dusterjohn]
#2544581
09/02/18 12:31 PM
09/02/18 12:31 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Thanks cab, our ati was about 5,700 but was still to tight, so I sent it out for another 1,200 I hope that gets me closer .. Something just isn't right. That is going to put your launch rpm just 600 rpm less than your shift point. I think a 5,700 rpm launch should be good enough for much better 60 ft. than 1.70's. You need to look in another direction. Are you sure you aren't leaving in second gear?
[Re: 70dusterjohn]
#2544669
09/02/18 02:49 PM
09/02/18 02:49 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m going to say this about as simple as it gets. Get the car to 60 foot and the rest is all downhill from there. The first sixty foot is the hard part.
