Date codes on lower control arm rivets #2544349
09/01/18 06:22 PM
09/01/18 06:22 PM
AndyF Offline OP
AndyF  Offline OP
Is there a decoder ring for the numbers stamped on the rivets of the lower control arms? The numbers are three digits such as 811 and 268 on a B body control arm. The numbers don't appear to be week and year or day of year. Anyone know what the numbers mean?
Re: Date codes on lower control arm rivets [Re: AndyF] #2544353
09/01/18 06:28 PM
09/01/18 06:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From my 1970 Valiant;
Lower control arms 021 069 (1970, second shift, line one) & 69th day of 1970 = March 10th, 1970
Re: Date codes on lower control arm rivets [Re: AndyF] #2544358
09/01/18 06:46 PM
09/01/18 06:46 PM
AndyF Offline OP
AndyF  Offline OP
So it is two different codes? They both have the year in the first digit but then the day on one rivet and line info on the other rivet? That doesn't seem to work with the codes on this control arm.
Re: Date codes on lower control arm rivets [Re: AndyF] #2544359
09/01/18 06:48 PM
09/01/18 06:48 PM
AndyF Offline OP
AndyF  Offline OP
The arm pictured above could be from 1968 since it has the anti-sway bar tab on the outside, but that would mean that 811 is 1968 and the 11 is something else. While the 268 would be 26 means something and then 8 is for '68. But that is backwards from TA's example.
Re: Date codes on lower control arm rivets [Re: AndyF] #2544363
09/01/18 06:59 PM
09/01/18 06:59 PM
USA
rftroy Offline
rftroy  Offline
USA
From TA’s example, wouldn’t your’s be: 1968, first shift, line 1; and 268th day of 1968?
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Date codes on lower control arm rivets [Re: AndyF] #2544364
09/01/18 07:00 PM
09/01/18 07:00 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
811 decodes as:
8: 1968
1: first shift
1: first line
268 decodes as:268th day of 1968 (Sept 24th)
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Date codes on lower control arm rivets [Re: AndyF] #2544365
09/01/18 07:01 PM
09/01/18 07:01 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
268 is the day in the year that the LCA was put together.
268th day in 1968 for a early 69 build automobile.
The first digit 8 on the other rivet head is the year, the other digit's are the assembly line that it was manufactured on, and the shift that it was put together.
But i forget which of the two, are which, without looking it up.
Pretty much meaning less anyway, in code deciphering.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Date codes on lower control arm rivets [Re: AndyF] #2544366
09/01/18 07:01 PM
09/01/18 07:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
811 - 1968 First shift, line 1.
268 - 26th day of 1968.
IF what I was told when I asked here long ago is correct?
(I have not looked at enough of these to know if the date code on the 2nd rivet ever went into 4 digits.)
Re: Date codes on lower control arm rivets [Re: Alaskan_TA] #2544373
09/01/18 07:32 PM
09/01/18 07:32 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
268 is the 268th day - not the 26th day of 1968. (The 26th day would be a 1967 model)
Re: Date codes on lower control arm rivets [Re: AndyF] #2544375
09/01/18 07:40 PM
09/01/18 07:40 PM
AndyF Offline OP
AndyF  Offline OP
Okay got it. One rivet has the day of the year starting at 001 while the other one is the last digit of the year and then line and shift info. That makes sense for all of the ones I have on the shelf. And the year is the year of mfg not the model year. So anything past roughly day 180 will be the next model year.
Re: Date codes on lower control arm rivets [Re: AndyF] #2544377
09/01/18 07:41 PM
09/01/18 07:41 PM
AndyF Offline OP
AndyF  Offline OP
Oh, I forgot to mention that I have a set of B body control arms where the rivet heads are blank. Not sure what that means. Over the counter parts? Still seems like the mfg would mark them all since I doubt the mfg knew where they were going. Could be a missing stamp or perhaps someone sanded them smooth for some weird reason.
Re: Date codes on lower control arm rivets [Re: AndyF] #2544385
09/01/18 08:22 PM
09/01/18 08:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
OK, That makes more sense than what I said, thanks!
Re: Date codes on lower control arm rivets [Re: AndyF] #2544396
09/01/18 09:01 PM
09/01/18 09:01 PM
hemi71x Offline
hemi71x  Offline
The plant that manufactured the LCA's didn't start stamping them with codes until the end of the 1960's sometime.
So finding earlier ones without stampings is perfectly normal.
Re: Date codes on lower control arm rivets [Re: hemi71x] #2544454
09/01/18 11:24 PM
09/01/18 11:24 PM
AndyF Offline OP
AndyF  Offline OP
Okay, that makes sense. The set I have without any mfg stamps are from a B body car with the outboard LCA tabs. So they could be as early as a '66 model with mid-65 production date.
I snapped a picture of a '70 LCA with the mid-mount LCA tab. Looks like this LCA was put together on the 237th day of 1969 which would put it into the beginning of the '70 model year. Thanks everyone for the help.
Re: Date codes on lower control arm rivets [Re: AndyF] #2545065
09/03/18 01:13 PM
09/03/18 01:13 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
I have had this graphic saved for years - it's accurate at least as far as the 1970 Challenger I own. The second photo is one of the LCAs from my car, an R/T SE with spd of 109 (1970). Though not a b-body, it seems to support the three digit meanings.
