Re: Date codes on lower control arm rivets
[Re: AndyF]
#2544363
09/01/18 06:59 PM
09/01/18 06:59 PM
Posts: 704 USA
rftroy
USA
From TA’s example, wouldn’t your’s be: 1968, first shift, line 1; and 268th day of 1968? Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: AndyF]
#2544364
09/01/18 07:00 PM
09/01/18 07:00 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
811 decodes as: 8: 1968 1: first shift 1: first line
268 decodes as:268th day of 1968 (Sept 24th)
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: AndyF]
#2544365
09/01/18 07:01 PM
09/01/18 07:01 PM
Posts: 5,360 Rancho Cordova, California (Sa...
hemi71x
268 is the day in the year that the LCA was put together. 268th day in 1968 for a early 69 build automobile. The first digit 8 on the other rivet head is the year, the other digit's are the assembly line that it was manufactured on, and the shift that it was put together. But i forget which of the two, are which, without looking it up. Pretty much meaning less anyway, in code deciphering.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Alaskan_TA]
#2544373
09/01/18 07:32 PM
09/01/18 07:32 PM
RealWing
Ontario, Canada
811 - 1968 First shift, line 1.
268 - 26th day of 1968.
IF what I was told when I asked here long ago is correct?
(I have not looked at enough of these to know if the date code on the 2nd rivet ever went into 4 digits.) 268 is the 268th day - not the 26th day of 1968. (The 26th day would be a 1967 model)
[Re: AndyF]
#2544396
09/01/18 09:01 PM
09/01/18 09:01 PM
hemi71x
Oh, I forgot to mention that I have a set of B body control arms where the rivet heads are blank. Not sure what that means. Over the counter parts? Still seems like the mfg would mark them all since I doubt the mfg knew where they were going. Could be a missing stamp or perhaps someone sanded them smooth for some weird reason. The plant that manufactured the LCA's didn't start stamping them with codes until the end of the 1960's sometime. So finding earlier ones without stampings is perfectly normal.
